back up camera help
Old Jan 8, 2009 | 11:16 AM
fordfanaw's Avatar
back up camera help
I am wanting to hook up a backup camera in my 07 fx4. I was really wanting to use the '09 emblem camera but after doing some reading I found that they mount different so it won't work. So now I am going to the '08 tailgate handle mount. I curently dont have the backup camera in my truck. So what do i need to make this install. I want to hook it to my nav unit but do i still need to get the camera rear view mirror?
Old Jan 8, 2009 | 12:37 PM
Boataddict's Avatar
I have it hooked to my head unit. It works great. You do not need the mirror.
Old Jan 8, 2009 | 01:47 PM
fordfanaw's Avatar
so all I need is the handle (mount for cam) and a cam right? I seen where people hooked it up to aftermarket units do you know what i need to do to hook it up to my factory nav unit?
Old Jan 8, 2009 | 06:53 PM
Ronix's Avatar
I bought the handle assembly and a camera off ebay which was $ 24.00
41mm x 29mm diameter face
You will need a multi bit drill bit to make the stock hole bigger to fit the camera.
You have three things to connect. Power, Video, and ground. real easy setup
Old Jan 8, 2009 | 11:03 PM
jrb03's Avatar
Im pretty sure the factory nav unit does NOT accept an incoming video signal, somebody correct me if im wrong. You will either need to buy the rear view mirror with display, or replace the nav unit with aftermarket unit ready for reverse cam.
Old Jan 9, 2009 | 11:09 AM
fordfanaw's Avatar
can some one help me out to let me know if what jrbo3 said is right?
Old Jan 9, 2009 | 12:18 PM
Ronix's Avatar
I would assume he is correct as well.
Old Jan 9, 2009 | 12:57 PM
racinwarrior's Avatar
he is correct....that is why Ford has the mirror....people didnt want to pay $2500 for nav and camera so using the mirror as the display made more sense cost wise
Old Jan 9, 2009 | 01:31 PM
fordfanaw's Avatar
its there a way to bypass the mirror to put it on the nav insted?
Old Jan 12, 2009 | 12:28 PM
the factory nav does not have the input jacks to connect any other video sources.....there isnt anyplace to plug it in to...
Old Jan 12, 2009 | 12:31 PM
Low_e_Red's Avatar
Yes, it can be done into the nav screen.
You need to get a hold of Suzanne Lazarev over at Nav-tv. Just tell her Ryan Py (from the insider sent you)
