Revers camera install PLEASE HELP
Old Dec 30, 2008 | 05:49 PM
sal150's Avatar
Reverse camera install PLEASE HELP
I just got a Boyo vtl-300c reverse camera, im not sure if anyone is familiar with this model but it came with a wierd setup.
This is what it looks like
I have the d3 and i wanted to install the camera so when i put it in reverse the camera goes on, on the screen. i dont see how thats possible with this setup can someone help me out please.
Thanks alot
-Sal
Old Dec 30, 2008 | 07:20 PM
Boataddict's Avatar
Just run the RCA to the pioneer and hook the power wires to the reverse light circuit.
Old Dec 30, 2008 | 07:21 PM
Boataddict's Avatar
Or the head unit must have a wire to run to the reverse light circuit as well.
Old Dec 30, 2008 | 07:26 PM
sal150's Avatar
Thanks for responding, So your sayin that their is a reverse wire hooked already from the head-unit to the circuit. And if not all i have tyo do is splice into the circuit and as soon as i put it in reverse the screen will change to the camera.
Thanks for the help Im completely lost
-Sal
Old Dec 30, 2008 | 09:39 PM
Boataddict's Avatar
-Sal
Do you have a manual for the head unit? There should be a reverse wire. It is the only way it would know to turn the camera on when backing up.
Old Dec 31, 2008 | 08:13 AM
racinwarrior's Avatar
you have to find the reverse power wire(it have 12 Vdc when in the reverse gear position) and splice that to the head unit. this will tell the head unit to auto switch when you put the trans into reverse. If you head unit does not have this wire you will have to manually switch it to AUX everytime you wanna see the camera. the HU should also have a AUX or BU CCAM video input (yellow RCA) this get attached to the yellow plug on the camera you have. (from the HU down along the truck frame back to the camera with one single long RCA cable) gound the black wire on the camera and splice the red into the reverse lights. if you have the 7-pin trailer plug you can pick it up there. REMEMBER TO SOLDER ALL CONNECTIONS DO NOT USE THOSE 3M 3 Way things
Old Dec 31, 2008 | 08:19 AM
05_sprcrw's Avatar
If you don't have the manual I will look it up for you tonight and tell you which wire you need to tie into. I know it has something about it in the manual. Also you can go to this website dedicated to the avic series and they really know there stuff.
http://www.avic411.com/
Old Dec 31, 2008 | 10:31 AM
Low_e_Red's Avatar
WAIT!!!!
First, tie switched power and ground to the Rvrse cam.
Plug, the RCA into the monitor's brown RCA connector
Then, take and connect the Purple/White wire on the back of the D3 to the Black/Pink wire low in the DKP. (Its the only Black/Pink coming out the grommet underneath your feet.
Old Jan 4, 2009 | 12:23 PM
sal150's Avatar
I looked threw the whole manual and found nothing im going to try to do it today. Are you guys saying its possible or its a possibility that it would work when i go into reverse.
Thanks for the help this stuff confuses me.
Thanks alot
-Sal
Old Jan 4, 2009 | 01:47 PM
jrb03's Avatar
You've been told in very plain english what you need to do. If your still unsure of how this works I would highly recommend you not mess with this at all and take it to a professional.
Old Jan 25, 2009 | 12:48 AM
pmason718's Avatar
I have this same camera, great choice.
Old Jan 25, 2009 | 01:34 PM
Mark05KR's Avatar
The information you seek is NOT in the owners manual. It is in the installation guide.
http://www.pioneerelectronics.com/pi...Manual0221.pdf
Go to page 13.
