F150 Install AVIC F90BT Need HELP!
I'm planning to install a pioneer avic-f90bt in my 1999 f150 truck. When i pulled the radio
out I notice two RED(2) connector. 1 which I believe is the primary containing all the necessary
wires(16 Pin). The other, with only about 8-10 wires(20 Pin). The radio is premium sound with a single
CD and has support for the speed sensor and it works as described. I believe this second connector
contains the speed sensor wire(Gray/Black stripe). Questions?: 1) What is the correct harness(s) for
the avic-f90bt hookup? 2) Do I have to bypass the built in AMP, If so, does anyone know the exact
location of the AMP?? 3) Is the speed sensor wire on the factory harness?
Pictures would be great!!!!!!
Any help will be greatly appreciated!!!!!!
