TV tuner
TV tuner
Does anyone have any ideas what to use for an antenna with a tv tuner? I have a digital box hooked to my Z2, but the antenna I have is huge. Is there any way to tie the antenna wires into the chassis for good reception?
I was at the local radio shack and I seen TV antennas there pretty small that were wing shaped. On my headunit the tv antennas are wires and they have little plastic holders that stick on my rear window holding the wires in place. You'll have to check your connection types though because I think most aftermarket antennas use standard RJ6 connections.
i got two wire antennas that go around my front windshield held on by those little plastic holders Impact9 is talkin about. check ur local stereo shop. the reception is better with two long ones.
