pioneer d3 help
Old Nov 24, 2007 | 11:02 AM
07screw's Avatar
pioneer d3 help
I had my d3 installed the other day and now my factory sub does not play
the guy told me the only way to get it to work is to buy a small amp
is this true or am i gonna be spending money that i dont need to?
Old Nov 24, 2007 | 11:15 AM
SAJEFFC's Avatar
Nope, not true. I too had the D3 installed last week. There is a special harness available for Ford Audiophile systems that makes the sub work. You do have to add a 5volt resistor in the line to the sub amp so it wont pop when you turn it on. I would tell your installer to do a little research on it.
Old Nov 24, 2007 | 12:57 PM
gonefishin10's Avatar
this is why i recommend doing the research and installing yourself, it is a piece of cake. 3/4 of the installers i have spoken with have no clue what the hell they are talking about.
as stated above, there is a special harness.
this is the harness that you need
http://www.crutchfield.com/App/Produ...705521&tp=2977
Old Nov 24, 2007 | 03:10 PM
SAtownTX's Avatar
yup i agree gonefishin. i got the d3 and i did it for my first EVER car audio install. After getting all the wiring and diagrams from crutchfield, it was a piece of cake. i did have the audiophile sub when i installed it (have upgraded.) and that harness will work but when you turn on there is a loud thump. nothing wrong but if you want to get rid of it, someone posted the correct resistor you needed to put in between the harnesses. Good luck
Old Nov 25, 2007 | 01:31 AM
Low_e_Red's Avatar
5v eh? DAMN what you doing? How bout 2 1K ohm, 1/4W, 12v resistors... One to gnd one to the amp.
Old Nov 26, 2007 | 08:38 AM
SAJEFFC's Avatar
Ehh....that's what I meant to say.
Old Nov 27, 2007 | 01:45 PM
DRJ's Avatar
DRJ
Give your installer this and tell him to figure it out nah don't take it back to him!! If you are handy do it yourself!
I just tapped into the line level out bn/or rd/blk by putting an RCA male end on them then plugged the rca to the mono sub input on an in dash (if you have the pair of inputs use 2 ends or splitter), then ran a remote turn on to dg/vt, of course wire in your resistors to avoid the pop!
Old Nov 27, 2007 | 01:54 PM
DRJ's Avatar
DRJ
Better *** diagram..
Old Nov 27, 2007 | 06:53 PM
07screw's Avatar
thanks for all the help I got it working with that wiring harness for the sub and it came with the resistor
