IVA-W205 Installed!
Old Aug 1, 2007 | 06:44 PM
allstar8806's Avatar
if i plan on installing the bypass next week do i still have to connect the parking break and foot break wires??
Old Aug 1, 2007 | 07:11 PM
B-Man's Avatar
Originally Posted by twmalonehunter
...<Snip>If so, where are you going to put your antenna?...<Snip>
I put mine under the oblong plastic panel on the passenger side of the dash...
Fastened it to a bracket under there and it works flawlessly.
Completely stealth and easy to remove later, if you need to...
Old Aug 1, 2007 | 07:12 PM
B-Man's Avatar
You won't need to connect anything to the parking or brake wiring if you use the PAC-TR7 bypass gimmick.
Old Aug 1, 2007 | 07:17 PM
RollingRock's Avatar
If you are using the PAC bypass then no. The PAC utilizes a series of events during "boot" up that makes the unit think its in park.
Old Aug 1, 2007 | 08:13 PM
when grounding the head unit can i attach the ground wire to the thin metal that supports the dash??? or can i connect it to the wireing harness ground wire??
Old Aug 1, 2007 | 08:37 PM
twmalonehunter's Avatar
I wired mine into the wiring harness ground and it works fine.
Old Apr 29, 2008 | 12:41 AM
blackf150lariat's Avatar
sorry old thread but when connecting pac tr7 says hook to accessory connection.....where is this .
Old Apr 29, 2008 | 11:53 PM
Low_e_Red's Avatar
red.
Old Apr 30, 2008 | 08:19 AM
ty LOW
will try after work
