Woot.. Got the AVN5500.. Wiring Questions?
Old Jan 15, 2007 | 06:09 PM
goldmember's Avatar
Thanks. Just curious. Because the avn6600/5500 are comon swaps in the 05 and newere tacomas that I have. Elclipse decks are plug in play with Toyota factory harnesses unless you have a JBL system and the steering wheel controls work.
Old Jan 15, 2007 | 07:27 PM
RollingRock's Avatar
Originally Posted by SSpiro
Was a lot easier then it seems.
e-brake wire: Just ground it.
reverse wire location: Located at the fuse block at the kick panel on the passenger side.
speed pulse wire location: Located in the harness behind the radio.
This thread has EVERYTHING you need.
http://www.fordf150.net/forums/viewtopic.php?t=31939
SSpiro are you in OK by chance?
Sprio OK?
Old Jan 18, 2007 | 09:40 PM
SSpiro's Avatar
Nope, In Florida...
Ordered my PAC interface tonight.
Old Jan 21, 2007 | 02:10 AM
SouthTexasFX4's Avatar
To get the backup sensors to work with the radio, you just tap into that wire near the fuse box? Does it mute the radio when they are activated?
Thanks.
Old Jan 21, 2007 | 01:22 PM
SSpiro's Avatar
No.. Backup sensors don't work with radio.. at least not the OEM ones.
You're confusing the reverse sensor wire - it's for the GPS.
