Backup Camera Wire Routing, 12VDC Source
Old Sep 10, 2006 | 07:08 PM
Zaairman's Avatar
Originally Posted by evtide
The good, the bad, and the wtf:
The good - I got my backup cam installed.
The bad - the damn thing was just too big in diameter to mount up at the tailgate latch without trimming away some sheet metal and I was afraid I'd wreck it for sure (I REALLY wanted it up there).
The wtf - the cam does work, but it doesn't come on auto when I shift into reverse like it should.
I tapped the 'reverse' wire from my Kenwood head unit into fuse #14 (05 SuperCrew Lariat), and am pulling the DC for the camera at the center backup light wire on the 7 pin connector - live only when in reverse.
It worked fine when I did a dry run by powering the cam with a wall charger and hooking up the purple Kenwood wire to the known hot on the cig. lighter to simulate reverse. When in any mode, the head unit switched to the cam when I livened up the wire, and returned to normal when I cut the juice. On the final install the head unit doesn't switch back and forth from a normal display to the backup camera when I shift in and out of reverse. It does work, but I have to **** around with the buttons to pull up the bumper camera display.
I'm now wondering if the trouble lies in the fuse panel, like a crossed wire or something. Man, I'd like to throttle the Ford engineer who designed and placed the fuse relay system in this truck. The '02's was on the drivers side, plenty of light and clearance.
It's getting dark out and I'm fairly well pissed off, but I'll figure it out one day this week.
Hmmm...I attached my reverse wire on the headunit to the reverse wire on the trailer wiring, and the power wire to the camerea to the 12v constant on the trailer wiring.
Old Sep 10, 2006 | 09:40 PM
ribbie78's Avatar
thinking out-loud
What's the bottom circle on your bumper? Is that a backup sensor like a radar? I'm assuming the top is your new camera. Nice install job!
what about the video settings on your HU? is there a setting for "auto reverse cam" on there? -nevermind you said it was working fine when testing it...
like Zaairman said, i have it all wired into the trailer 4pin connector too
...would there be too much interference if you ran the reverse sensing kenwood wire back to the trailer harness near the video lead? maybe just send it down the other side of the truck so it doesn't get "noise". Maybe test it tomorrow by connecting a loose wire from the deck reverse wire back to the trailer harness and see if it comes on the way you want it to.
At least it looks good back there!
Old Sep 10, 2006 | 09:43 PM
Zaairman's Avatar
No no no...4 pin isn't wired for reverse or 12v constant. You MUST have the 7 pin wiring to hook it up like I did...
Old Sep 10, 2006 | 10:45 PM
ribbie78's Avatar
oh yeah. Mine's just on with parking lights.
Old Sep 11, 2006 | 12:35 PM
RollingRock's Avatar
Originally Posted by whitecrystal1
I installed a camera made by Vizualogic. It came with the license camera. I ran the wires through the frame, using a fish tape. To get the wires in the cab I ran them through the plug on the passenger floor pan the up into the dash. I ran the monitor cable up the piller and installed it on the windshield. I did use the 12v on the 7pin. It's the wire in the center I think it was blue. Mine can be on all the time because it is also hooked up to a ignition 12v circuit as well so I can turn it on and leave it on with the key. The set up I bought has a hook up for two cameras. It's the VIZUALOGIC HINDSIGHT c-1000 model.
Tried to send you a PM on your camera, can you shoo me your contact info via email for a few quick questions?
Old Sep 11, 2006 | 05:08 PM
whitecrystal1's Avatar
Edited out email
Old Sep 12, 2006 | 11:42 PM
ribbie78's Avatar
here's mine in the handle; a little off center but it doesn't touch any metal, and I didn't have to shave,grind, or take the handle out to mount it:
Hey Zairmann, did you get the wiring issue resolved ? it looks like i overlooked a detail...when i step on the brake the camera signal goes out (or maybe gets TOO much juice) using the 4 pin on the left of the tow package wiring. Oh well, i'll have to tinker with it this weekend. I'd like to be able to turn it on with just the light switch so i don't need to run any extra wires. Which pins are you using on the round connector? thanks
Old Sep 13, 2006 | 12:10 AM
Zaairman's Avatar
I've never had any wiring issues with my camera...
Old Sep 13, 2006 | 12:34 AM
ribbie78's Avatar
Crap. I need to quit posting at night
It was you quoting evtide a while back and he was having some issues. No wonder I'm having a tough time. hahaha
You're keepin me sharp Zair
Old Sep 13, 2006 | 07:15 AM
evtide's Avatar
I LIKE the cam placement Rib. I wish my cam was narrow enough to fit there - that was my original plan. BTW, I did take the tailgate handle all the way out when I was testing various locations. It's a piece of cake, but I indexed the two threaded rods, the up/down placement of the latch assy., and the placement of the plastic handle with a paint pen BEFORE I started undoing the two nuts. That way I was sure it would go back in exactly the way it was originally.
Old Oct 15, 2006 | 03:25 AM
MSkates's Avatar
Hi guys,
I just got a 07 F150 and am hoping to find out how I can easily wire to something that is "always on" to allow the camera to be on demand. Is there a source for wiring info for the truck you guys could recommend?
Old Oct 15, 2006 | 08:30 AM
evtide's Avatar
If you have the tow package with the 7-pin connector, there's a wire that's live whenever the ignition (probably accessory, too) is on. I forget the color/position, but the spring loaded cover on my '05 has a diagram that shows what pin is what.
This is what I used for my camera install and I can turn the cam on whenever the truck is running.
As an aside, my head unit displays the cam video when the truck is started, and it's saved my butt a few times as it prevented me from pulling away with the tailgate down.
Good luck!
Originally Posted by MSkates
Hi guys,
Old Oct 15, 2006 | 08:43 AM
Good luck!
evtide, where are your picture of your set up. I'd like to see how it turn out.
Old Oct 15, 2006 | 09:09 AM
evtide's Avatar
I only have pics of the cam installed in my bumper. Scroll up or go to page 1 of this thread and you'll see it off to the left of the license plate and above the reverse sensor.
Old Oct 15, 2006 | 09:29 AM
oops, sorry I should have look first. Funny thing is I saw you post that a while ago. I forgot I guess I'm getting old
