Eclipse Nav system "factory sub don't work"
Old Mar 6, 2006 | 09:51 PM
tlytle01's Avatar
Has anybody hooked up an Eclipse Navigation system and the factory sub not work at all. I have a 04 Super Crew with factory audiophile. Removed the head unit and installed my new Nav ( which totally kicks *** --- A MUST HAVE ITEM ) My factory sub doesn't work
HELP PLEASE
Thanks , Tracy
Old Mar 6, 2006 | 10:23 PM
Rockpick's Avatar
Moderator &
Which Eclipse unit do you have?
Old Mar 6, 2006 | 10:26 PM
tlytle01's Avatar
Avn 50 D
Old Mar 6, 2006 | 10:31 PM
Rockpick's Avatar
Moderator &
Check page #6 of your installation manual if you have a 5435...Square #5 shows what you're looking for...
Additionally, I received a 'pig tail' that converts the 'blue/white' wire (listed as CONTROL POWER SUPPLY for external amplifier), to another blue/white wire that crosses into COAX (white/red). From there, it's a simple plug and play into the audio out (oval C & oval D).
Long story short, the head unit isn't able to send a signal to the sub because the subwoofer signal is sent via the blue wire which isn't probably connected to the LINE OUT via RCA cable.
Old Mar 6, 2006 | 10:33 PM
Rockpick's Avatar
Moderator &
Well, I guess that post was generally useless eh?
The concept should be about the same though.... you still have to tell the amp to kick on so that it'll work. Check your installation manual to see how you can connect it... It should be activated via the blue/white wire in your factory harness.
Old Mar 6, 2006 | 10:52 PM
tlytle01's Avatar
AVN 50 is the same ( I am told ) as the 5500.... so it might work, Thanks I'll look into it
Old Mar 6, 2006 | 11:13 PM
HTRDLNC's Avatar
HELP PLEASE
Thanks , Tracy
The sub wires are actually in a different plug than the regular speakers and power. Metra makes an adapter for it. Then you can hook up sub-out of your radio to contrl the factory sub. I have it that way and it sounds great.
Old Mar 7, 2006 | 01:32 AM
tlytle01's Avatar
Thanks so much............ that is what I was looking for, I was given the wrong plug
Old Mar 7, 2006 | 09:44 PM
nothinbutaford's Avatar
Don't forget to add a 1.5kohm resistor in line with the blue remote turn on. This will prevent turn on pop noise. Also the 50d I believe does not have sub volume control so the sub may overpower the rest of the system. Its an easy fix, just get a low pass filter with an input gain adjustment and that will take care of it. It will also make the factory sub sound better (less boomy) crossed over.
Old Mar 7, 2006 | 11:16 PM
F150Truck'in's Avatar
it has sub level control, 1,2,3,4, but no pre-out, i'm confused on this on mind....
Old Mar 7, 2006 | 11:17 PM
do you have the Metra part number??
Old Mar 7, 2006 | 11:19 PM
tlytle01, did you just get it off ebay, I got one also.....
Old Mar 7, 2006 | 11:25 PM
You should have gotten a plug for the back of the radio w/front, rear and non fade(sub) outputs. Where did you get the eclipse?
Old Mar 7, 2006 | 11:47 PM
they don't give that harrness with the AVN20D, 30D, 50D.. the harness you get is the same but without preouts...
got it off ebay, guy must have word for visteon, because thats where it shipped from...
Old Mar 7, 2006 | 11:53 PM
I've got 25 30D's in stock and they all have the preout harness only the older 30D's didn't have it. I haven't got any 50D's in stock right now but I'll double check to make sure it has a preamp. Plus you said you had a sub level control is that on the info/settings screen along with wallpaper and guidetone.
