Lincoln Blackwood & Mark LT
blackwood air spring leak
Old May 9, 2010 | 10:31 AM
mlhailey's Avatar
Smile blackwood air spring leak
my right side air suspension bag will not hold air.I see a wet spot the size of a quarter so it must be a hole versus a crack.Ford does not sell it,it cost to much anyway ($360).Can these be patched or bought anywhere.Monday going to call suncore & americansuspension.Any input would be appreciated.THANKS...mlhailey
Old May 10, 2010 | 01:53 PM
mlhailey's Avatar
I called the dealership back & talked to different parts person.They had the air spring at there national parts depot.false alarm........dargel167
Old May 11, 2010 | 04:48 PM
mon74's Avatar
So how much was the price difference with the dealer VS. American suspension & suncore?
I hear mi wood's compressor work only once a month, but, you never know... (knock on wood)
Old May 12, 2010 | 09:46 AM
mlhailey's Avatar
suncore or american suspension do not have parts,only lincoln does at $300 bucks.Idid not have to buy one though.My air line (@the air spring) was not fully seated at the factory and it was just laying there.Pushed it back in(quick connect)loosened the adjusting bolt on the lower end of the air suspension height sensor & adjusted it down & the air spring filled up.adjustd the sensor back where it was & I am back in business.The sensor is right by the rearend inspection cover.I do have a blackwood workshop manual.My windshield washer pump quit also.Sliped it out of tank soaked it in white vinegar ,reached in the pump & rotated the shaft with a small screwdriver(shaft was froze up).That saved me $40.My wife is happy again until the truck tanks again.It helps having a manual.Happy motoring..........dargel167
Old May 12, 2010 | 09:55 AM
mlhailey's Avatar
About your air comp.It only comes on when it has to.Like when you ad weight to the truck.dargel167.............
Old Nov 21, 2012 | 07:56 PM
6T9Boss302's Avatar
Anyone know of any non OEM suspension bag replacements? I have searched the threads but have not found anything recent. Thanks much for your reply.
