Lincoln Blackwood & Mark LT
Replace map light in front of sunroof?
Old May 5, 2010 | 09:21 AM
kbutton1's Avatar
I just noticed my driver's side map reading light (the one in the headliner you push on the lens to activate) must be burnt out. It looks like a fairly simple bulb replacement, but I thought I would ask around to see if there are any pre-cautions that need to be taken when replacing this small lamp inside the lens.
I don't like tearing plastic molding off unless I ask about the procedure first.
Both lamps have a plastic ring (molding) surrounding the lenses and there is a sunroof switch between them.
Looks like I need to pop the plastic ring off and then look inside to determine how the lenses/lamps come out so I can replace the driver's side bulb.
Any suggestions would be appreciated.
