Just wondering LT.......
Anyone here planning on taking the back seat out of your LT for some reason or another (just the back rest) can you take a look at a little black box on the driver side looks like a relay almost it's for the power folding mirrors. Can you check and see if the wireharness that is on it has a part number and let me know what it is. Also if you're in the mood to lift the driver side power panel (arm rest) let me know what the stamped number on the mirror switch is.
Taking the back part of the back seat out is easy, remove the small cover on top of the seat belt retractor, remover the 2 10mil nut, pull the cover off,
Then put your hands in the crack of the seat and pull really hard up it will just pop off (unless your a girly-man)
