just wondering...
Old Dec 9, 2002 | 05:22 PM
FastAsL's Avatar
just wondering...
...if anyone else here runs their heater with the engine off while at the track to kool down the engine? i thought of it the other day at the track, and my truck kooled down much faster. also, after sitting for a while it started blowing colder air, so i started it for a second then shut it back off to cool more of the fluid. it worked really well. just put the key in the "on" position without starting the engine.
i thought "hey, im a genius" and i was thinking how many other genius' were out there.
BTW: WHOOOOOOOOO HOOOOOOOOOOO 1000 posts baby!
Old Dec 9, 2002 | 05:37 PM
SpankDog's Avatar
Banned
I ran the heater last time i was at the track just to keep me warm, so I guess I was cooling the truck too.
Old Dec 9, 2002 | 05:43 PM
Don's Bolt's Avatar
I allways do that
I also run the heat at full blast untill I stage, then I turn it off
Old Dec 9, 2002 | 05:54 PM
mecca's Avatar
I haven't run at the track at all, but it sounds like thats a great idea. Ill hafta try it when I finally get up to the track...
-Mike
Old Dec 9, 2002 | 07:37 PM
LIGHTNINROD's Avatar
That's an old trick that I learned a long time ago. It can also save you from overheating an eng. if you're caught in a traffic backup. I'd rather be hot and maybe save the eng.
And for all you snow-bound yankees, don't forget to run the air conditioning every week or so to keep the seals lubed .
Dan
Old Dec 9, 2002 | 08:13 PM
PT's02L's Avatar
For many years (at least 15), US automakers have made the "heater" cycle the A/C compressor every once in a while for just that purpose. I haven't checked the L, but I assume Ford still does it. Speed tip - to the best of my knowledge, Vent (Panel) is the only A/C - Heat selection (other than Off) that will not cycle or otherwise turn on the A/C compressor.
Old Dec 9, 2002 | 10:08 PM
FastAsL's Avatar
i also believe that the "panel" position is the only one that will run the heat/cool without the compressor running...chris
