swaybar endlinks! I CAN'T FIND THEM ANYWHERE !
Tim,
Nice pic of the QA1 heim kit. Any additional tips on mounting them over and above what you sent in the email?
<<==expecting my QA1's any day
Bob
Bob
Originally posted by Speedin Bob
Tim,
Bob
Tim,
Bob
For the passenger side, I used a c-clamp to hold the mount steady until the first hole was drilled. If you have a grinder, it might be worthwhile to bevel off the back edge of the mounting ring, as it is slightly larger than the concave mounting area. No need to remove either shock, but make sure you have a full set of SAE wrenches, as the QA1 nuts are kinda off sizes and large (can't remember). I did not have any threadlock handy, so I may go back and add it to the stem threads.
For the driver's side, remove all six T-60 bolts holding on the bed, then reinstall two on the passenger side about four turns. Jack up the driver's side of the bed a couple of inches with an 18" piece of 2X4 placed on the rearmost crossmember of the bed (the 2X4 slips in between the leaf and the frame). Once you get the bed up--it's easier than it sounds--the driver's side is easy. Total time should be an hour or so.
Let me know if I can answer any other questions.
As always, thanks for the tips.
Bob
