swaybar endlinks! I CAN'T FIND THEM ANYWHERE !
either everybody is straight retarded or nobody around me has anything.
i can't find 3 3/8 endlinks, hell most places don't even have them on file. where else can i get them online? |
check out so-cal speedshop online...
:) Daniel |
didn't find anything there
3 3/8" Energy Suspension, part # 9-8119. They are available in every parts store I have been to. If the precise size is not in stock, have them ordered.
Also available online at www.jegs.com |
Probleminfected
check with B & B auto parts : Renton, Bellevue Kenmore and Redmond....JR |
Links
I am glad that Probleminfected asked that question. I have been reading threads for a year about lowering. Everyone just slaps in lowering shackles and front springs, usually in their driveway and no one even mentions sway bar links. I have read captianoblivious's site (have it under Favorites) but still don't really understand. If the front is lowered 1", then should you install 3 3/8" links? What about the back with a 2" drop? captianoblivious speaks about cutting and rewelding. Do most people who do a 1"/2" drop just ignore the links? I would really like to lower the truck, but until i understand this, I'm just lurking. Thanks
I just installed a roush overall 3-4.5" drop on the L. I had previously cut the rear sway bar end links down by 2" for just drop shackels. I put 2 5/8" Energy Suspension end links on the front , bought at Pep Boys....they had an assortment.
Originally posted by Probleminfected didn't find anything there |
Re: Links
Originally posted by Neal W What about the back with a 2" drop? captianoblivious speaks about cutting and rewelding. Do most people who do a 1"/2" drop just ignore the links? I would really like to lower the truck, but until i understand this, I'm just lurking. Thanks You can drive forever and not do anything and it will still drive and corner, just not as well (or optimum).From what I have read on the boards, the anti-sway bar works its best at parallel to the ground.It will still work(just not as well when not parallel). I cut and welded mine. https://www.f150online.com/galleries...1645-31193.jpg https://www.f150online.com/galleries...1645-31194.jpg |
found some
well they aren't energy suspension, but i found some at shucks.
funny people are real fing stupid at part stores. ride feel a hell of alot better, even better then stock. thanks though guys. i still need rear endlinks for the shackles, i don't have access to a welder. though i think the body shop at work might let me use theirs, but i've only used a welder once. |
Re: Links
Originally posted by Neal W I am glad that Probleminfected asked that question. I have been reading threads for a year about lowering. Everyone just slaps in lowering shackles and front springs, usually in their driveway and no one even mentions sway bar links. I have read captianoblivious's site (have it under Favorites) but still don't really understand. If the front is lowered 1", then should you install 3 3/8" links? What about the back with a 2" drop? captianoblivious speaks about cutting and rewelding. Do most people who do a 1"/2" drop just ignore the links? I would really like to lower the truck, but until i understand this, I'm just lurking. Thanks http://www.timskelton.com/lightning/...rear_sways.jpg http://www.timskelton.com/lightning/...end_links2.jpg Wow! Handling is much crisper. The high-speed oversteer (kind of a wandering feeling at very high speeds) is reduced and the turn-in and low-speed handling is massively improved. My truck absolutely tears up a 20 MPH city street turn. Taking it to the track next weekend for some at-the-limit evaluation. p.s. - before anyone comments, I replaced the bump stops. |
Re: Re: Links
Originally posted by Tim Skelton ... p.s. - before anyone comments, I replaced the bump stops. |
I've got some extra stock
PI:
Throw me an e-mail. I've got some extra stock rear endlinks and I'm pretty sure I know a shop who would whack wahtever out of them for you. Coldie |
e-mail sent
| All times are GMT -4. The time now is 06:41 PM. |
