Optimal Battery Relocation Question
Old Nov 28, 2002 | 03:33 PM
NOSTROMO
Guest
Posts: n/a
I plan to relocate the battery to reduce the weight bias. Did anyone here ever scale the truck and find the "optimal" location? I was going to take a guess and shoot for somewhere aft of the exhaust system on the right side. I would like to retain the spare tire but would give it the axe if need be.
Anthony
Old Nov 28, 2002 | 03:43 PM
dirtchicken's Avatar
I know some people put it in the right rear corner of the bed inside a battery box.
Old Nov 28, 2002 | 04:17 PM
Tim Skelton's Avatar
Re: Optimal Battery Relocation Question
Anthony
I assume you mean "optimal" for handling, as opposed to drag racing. Stan Martin mounts his box in the location you described. That is also where I am mounting mine.
Old Nov 28, 2002 | 05:02 PM
Spike Engineering's Avatar
Optimal for what? Daily driving, autocross, road course, drag racing, round-d-rounds...?
Who (driver weight)?
How much fuel in the tank (1/4 - full)?
Old Nov 28, 2002 | 06:53 PM
Neal's Avatar
Cool
HI!...
https://www.f150online.com/galleries...4-793-6940.jpg
https://www.f150online.com/galleries...4-793-6941.jpg
Old Nov 28, 2002 | 07:30 PM
NOSTROMO
Guest
Posts: n/a
Good Points Spike.... I Want to keep the battery under the bed and low. Idealy the perfect place to mount the battery would be in the middle of the chassis provided all other measurements were equal. As you probably already know, the front end is a brick as compared to the rear end. BY optimal, I meant mounting the battery to equalize the fore/aft weight bias. Obviously the battery alone will not equalize the two but will bring them closer together. The left and right sides of the truck also do not weigh the same but finding a useable spot is very limited.
The truck is not a racecar so finding the perfect point is not essential. I understand a compromise must be made as it is street driven and am not ready to start cutting components apart.
Spike since you asked for my weight, I am going to assume you have been through this already and would be able to give me your best guess......
192lbs.
Tank at Half
Old Nov 29, 2002 | 02:15 AM
192lbs.
Tank at Half
We are on exactly the same page, Nostromo. I am just going to crawl under there with my battery box and find a convenient place to bolt it in in roughly the location you described. May not be perfect, but close enough. I want to make sure it's easily accessible with just the back on jackstands.
