Autometer Boost Gauge Question?
Old Nov 28, 2002 | 12:24 PM
Tim Cowley's Avatar
Question Autometer Boost Gauge Question?
Ok well I sent my last boost gauge back cause it was reading 18lbs of boost. I connected this one and its still reading the same. The sensor is upside down like the instructions say, and I know theres nothing wrong with the gauge. Is there a way of connecting the boost hoses that I'm not aware of? Thanks!
Old Nov 28, 2002 | 01:22 PM
Don's Bolt's Avatar
do you have the electronic full sweep guage??
If so you may not have it wired properly, if you hook the pwer to the wrong circuit it will not work right.
Here is where you have to hook up the power
this is where I hooked up the MAP Sensor. Up under the driver kick panel, under the dash board
You can see the vacuum line in the pic too
Old Nov 28, 2002 | 02:11 PM
SpankDog's Avatar
Banned
Blah, don't stick stuff in the fuse panel..........knowing you Don I wouldn't think you would do something like that.
Old Nov 28, 2002 | 02:14 PM
02Thunder's Avatar
I wouldn't tap the fuse panel either.
joe
Old Nov 28, 2002 | 02:50 PM
Don's Bolt's Avatar
it is a special conection that has a slot in it, the fuse termilal slides through it. So it is not the type that stretches out the conections in the fuse panel. I hope that helps, I will go my friends shop and take a pic of it, so you will see what I meen.
I know the type of conector you are thinking about, and I agree they suck. When my friend told me about these new conectors I said ok lets try them.
Old Nov 28, 2002 | 04:24 PM
ASVTFordBoy's Avatar
Don, something this?
Old Nov 28, 2002 | 05:51 PM
SpankDog's Avatar
Banned
Cool Don, that sounds like its the right idea then, why not tap into a wire though?
Old Nov 29, 2002 | 07:34 AM
Tim Cowley's Avatar
Thanks to Don, I seen I had the white hose too long. Its working like its suppose to. I can't see full boost yet, cause I just have pumped gas right now. Going to try Xelene and the oil mixture today and see if I like it better then Toulene. Thanks Everybody!
