Bassani
Old Nov 21, 2002 | 12:43 AM
sfdbulldog's Avatar
Bassani
Just installed my new bassani cat-back. This thing looks and sounds awesome. No gain on the bottom end but on the top end it seems to have more legs and it just roars .
The only hard part was getting the old exhaust off. Now all I need is my cat pipe set up from RTKILLA and I will be set.
The only problem is my rear tip hangs lower than the front one, is this normal and if not what have you guys done to fix it?
SFDBulldog
Old Nov 21, 2002 | 08:43 AM
LIGHTNINROD's Avatar
I can't help but this will take it to the top.......
Dan
Old Nov 21, 2002 | 05:23 PM
Fast Gator's Avatar
My tips where at the same height. The only thing I can think of is loosen all the clamps and try adjusting the tips again.
BTW... you didn't use those POS Bassani clamps did you? If you did you better run, don't walk to the auto parts store and buy some regular muffler clamps. The Bassani don't hold
Old Nov 21, 2002 | 05:25 PM
SpankDog's Avatar
Banned
Mine seems to be the same way......I havent tried to adjust it but it might come up if you loosen the clamps and wiggle it around a little.
Old Nov 21, 2002 | 05:39 PM
RTKILLA's Avatar
I sent you that tracking number. did you get them today?
Old Nov 21, 2002 | 05:50 PM
sfdbulldog's Avatar
UPS said they were delivered,I will have my wife checks when she gets home. Thanks.
Matt
Old Nov 21, 2002 | 06:01 PM
WHITE01XXX's Avatar
I just walked out to the truck and mine are a hiar offset, they are a little adjustable, i am installing the high flow cats tonight for that all BASSANI system sound.
SEE YA !
Old Nov 21, 2002 | 06:18 PM
QuickSilver02's Avatar
When I originally installed my Bassanni cat-back, I was in a rush to hear how it sounded and the tips were not lined up right. I just loosened all of the clamps (don't forget the bolt right before the X pipe that lines the two pipes up) and put my floor jack (with rags on it so you don't scratch the tips) under the tips to hold them exactly how I wanted them to be lined up. Then just crawl under the truck and tighten everything down. When you remove the jack, the tips will drop down a tiny bit, so you may want to jack the tips up until they are almost touching the cut-out in the ground effects. And like Fast Gator said, ditch those Bassanni clamps that they give you. I just looked at them when I took them out of the box and threw them straight into the trash.
-NGK
Old Nov 21, 2002 | 06:56 PM
Fast Gator's Avatar
-NGK
I could have saved myself ALOT aggravation if I was as smart as you. I learned my lesson the hard way
Old Nov 22, 2002 | 12:04 AM
SVT150's Avatar
My tips are offset as well, but they fit well into the stock position (after some repositioning). It's just the back tips slightly lower than the front
Old Nov 22, 2002 | 11:44 PM
blue02lightning's Avatar
How much is the Bassani system and where did you buy it from?
Old Nov 23, 2002 | 12:59 AM
sfdbulldog's Avatar
$659 from blue oval performance. www.blueovalperfromance.com
Great service and prices. Mark is great.
SFDBulldog
Old Nov 23, 2002 | 11:52 AM
Fast Gator's Avatar
I bought mine from Mark at www.LightningForcePerformance.com
Seems like with shipping $670 or something
I might add I had them in a week after ordering
Old Nov 23, 2002 | 12:38 PM
DEIMATT's Avatar
AGREED!! Mark is the man!!!
I had mine before the week was out!!!
Tips are perfectly aligned..But had a muffler shop put em on for 75 bucks..Money well spent for this kid!!!
Old Dec 17, 2002 | 12:48 AM
motoxracer21's Avatar
sorry to bring up an old thread, but i was wondering if i could use the STOCK clamps with the bassani system or will i have to go out and buy some?
