is there a diff. with boost bypass kit and unplugging the boost bypass cable?
Old Nov 20, 2002 | 06:16 PM
ShaneMcKenna203's Avatar
becuase i have just unplugged my boost wire... thats ok right, or is there a difference with the 2....
Old Nov 20, 2002 | 06:19 PM
Fast Gator's Avatar
Yes there is a BIG difference.............
you save $25
Old Nov 20, 2002 | 06:26 PM
cool, thanks Joe for unplugging my bypass wire... i owe ya $25
Old Nov 20, 2002 | 10:54 PM
Tim Skelton's Avatar
you save $25
And another big difference: the computer may throw trouble codes if the wire is unplugged.
Do a search and scan the responses to this question, which has been asked many, many times. Lots of interesting opinions on what seems to be a simple subject.
One advantage to the pull-the-wire method is that you can just plug the wire back in. I do not advise permanently defeating either the boost dump or the torque reduction. Ford would not have put those safeguards in without a reason.
Old Nov 20, 2002 | 11:30 PM
run4bux's Avatar
That or go to your parts retailer and do it for three dollars. I did that which by the way I found the instructions on Chucks Lightning Page. I think it is worth $3, because I tried it the other way. peace
Stan
Old Nov 21, 2002 | 01:02 AM
cyntaxx's Avatar
unplugging throws a soft code which does set your "check engine light" or anything...and you can get rid of it by disconnecting the batt.....
Old Nov 21, 2002 | 05:30 AM
Fast Gator's Avatar
No check engine here, but there is a "soft code" set
