Cure for beltech 3/4?
Old Nov 18, 2002 | 08:03 PM
YZF-lightning's Avatar
IS there anyway i can raise the rear up some with m beltech kit? Like buy some other shackles? I just want it a little higher than it is, its on the "high" setting in the rear.
I really don't wanna C notch it, In 1st gear it still has some bounce and wheel hop.
Old Nov 18, 2002 | 08:26 PM
baddgene's Avatar
I was having a problem with mine last week when i got it installed. In the very top hole (1st or 4th depending on perspective), it hit very hard and often, and seemed bouncy too. Even over the slightest bumps. It also sat lower than the front end. Moved it down one hole, and havn't had a single hit. And for some reason, it's not a bouncy. Didn't have to shave the stops either.
Old Nov 18, 2002 | 09:28 PM
i moved it down a notch but it gets bad wheel hop in 1st
Old Nov 18, 2002 | 11:02 PM
trashguy's Avatar
are u guys using the bell tech shocks?
im lookin to do the 3/4 over the winter
i think im going with the doetsch tech
shocks,i hear they are stiffer.
