need a long tube header gasket for the collector, what size?
Old Nov 12, 2002 | 08:07 PM
beefcake's Avatar
i blew out the gasket that goes after the collector right before the cats on my kooks header setup,
what size gasket do i need?
3 bolt pattern, 2 1/2" or 3"?
Old Nov 12, 2002 | 08:08 PM
RTKILLA's Avatar
2.5 inch, get the copper ones!!!!!!!! THERE SO NICE!!!!
Old Nov 12, 2002 | 08:34 PM
Don's Bolt's Avatar
Beefcake
Ya Joe is right 2.5 inches
Make sure you really tightnen the bolts for the collector real tight, if you get any leak it will eat up the gasket.
This is what happened when I brought my truck to Level10 to get my trans worked on. They didn't tighten the bolts good.
Old Nov 12, 2002 | 08:42 PM
RTKILLA's Avatar
copper gaskets boys! that will solve all your problems!
Old Nov 12, 2002 | 09:15 PM
nminor's Avatar
I couldn't agree with RTKILLA more!! I was replacing those paper one's left and right. I bought the pair of copper through O'reilly's for around 20.00 . They are 2 1/2 " .
Old Nov 12, 2002 | 11:31 PM
captainoblivious's Avatar
I'm planning on getting copper ones over this winter. I hated those paper gaskets that came with it.
RT - how have the LT's been going back to the stock gaskets on the head? I'm thinking about doing that also.
Old Nov 13, 2002 | 09:08 AM
Ruslow's Avatar
I did not get gaskets with my LT.But then again I can't leave anything alone.Had new collector flanges made to fit 3 inch pipe.The collector is 2.75 then neckes down to 2.5 [for torque and scavenging at mid range]But since my stuff is top end I had them made for the 2.75 and uses a 3 inch collector flange to 3 inch cates and a Dr.Gas Xpipe,now it sounds like a rice rocket at RPM.MUSIC to MY ears.Stan
Old Nov 13, 2002 | 09:17 AM
ICULOKN's Avatar
The stock gaskets on the heads are the ONLY way to go. I blew out many of the paper ones on the heads!!
Old Nov 13, 2002 | 11:28 AM
RTKILLA's Avatar
yeah the stock ones where a snap to put back on the exhaust.
The biggest pain is that number 2 cylinder bottom bolt, HAHAHAHAHA. I hate getting that thing tight, extensions and rachets just don't work. Its all 10 milimeter 1/4 of an inch movement wrenching!
Old Nov 13, 2002 | 11:39 AM
easterisland's Avatar
Old Nov 13, 2002 | 12:12 PM
beefcake's Avatar
just picked up some mr. gaskets, they arent' the copper but needed something today
Old Nov 13, 2002 | 06:15 PM
Neal's Avatar
Cool
HI!... When I installed my JDM/KOOKS long tube headers and complete MAGNAFLOW S/S exhaust system, I used "PERCY's" DEAD SOFT aluminum collector gaskets. They are about a 1/8" thick and re-useable. No leaks here.
http://store.summitracing.com/global.../php-66001.jpg
