Dyno Numbers
Old Nov 12, 2002 | 12:26 PM
thundergod's Avatar
Dyno Numbers
After installing a custom burned chip, I put my truck on the dyno and got these numbers. Is it me or is the A/F ratio extra lean and dangerous. I would reccomend that anyone who buys a chip put your L on the dyno and make sure it is safe. The chip was from a very reputable tuner. Experts, please give me your opinion on these numbers. This is a chip burned for a 4# pulley. I put the chip on first and then did the dyno pull to see what the chip alone was worth. I didnt end up installing the pulley yet since it was running so lean. Shouldnt it have run very rich since it's supposed to be programmed for a bigger pulley?
Thank You,
The Dyno Edge
Title: Baseline
Run Date and Time: 11/8/2002 1:04: 10 PM
Acceleration from 3200 to 5800RPM, interval = 100.00RPM
Absolute barometric pressure : 24.55 in.Hg.
Vapor pressure : 0.12 in.Hg.
Intake air temperature : 70.4 of
Gear Ratio : 45.66 RPM/MPH
Correction Factor : 1.22 SAE
TIME RPM POWER TORQUE AIR/FUE SPEED
0.00 3200 82.1 134.7 14.8 70.1
0.44 3300 267.3 425.5 14.9 72.3
0.69 3400 282.8 436.9 14.8 74.5
0.94 3500 291.4 437.3 14.5 76.7
1.20 3600 298.9 436.0 14.1 78.8
1.45 3700 304.5 432.3 13.8 81.0
1.70 3800 311.3 430.2 13.6 83.2
1.96 3900 317.2 427.2 13.4 85.4
2.22 4000 321.3 421.9 13.4 87.6
2.48 4100 324.6 415.8 13.3 89.8
2.74 4200 330.9 413.8 13.3 92.0
3.01 4300 333.4 407.2 13.2 94.2
3.29 4400 337.0 402.2 13.3 96.4
3.56 4500 340.6 397.6 13.3 98.6
3.84 4600 343.2 391.9 13.2 100.7
4.12 4700 346.7 387.4 13.2 102.9
4.41 4800 348.5 381.4 13.1 105.1
4.70 4900 348.5 373.5 13.2 107.3
5.00 5000 349.5 367.1 13.2 109.5
5.31 5100 348.2 358.6 13.1 111.7
5.62 5200 347.9 351.3 13.1 113.9
5.94 5300 344.2 341.1 13.1 116.1
6.27 5400 340.3 331.0 13.0 118.3
6.60 5500 338.7 323.4 12.9 120.5
6.95 5600 333.0 312.3 12.9 122.6
7.32 5700 327.5 301.7 12.8 124.8
7.70 5800 319.6 289.4 12.8 127.0
Column Max
349.5 437.3 14.9 127.0
Column Min
82.1 134.7 12.8 70.1
Column Average
317.7 375.1 13.5 98.6
1
Old Nov 12, 2002 | 12:53 PM
02Thunder's Avatar
You are running LEAN, I would be careful. The temps drop, and you will start getting detonation, you just might not like the outcome.
Try and get your A/F fattened up a bit between the 4000-5800 range. Tip in Lean isn't a problem, but sustained Lean conditions will end the fun quickly.
joe
Old Nov 12, 2002 | 02:13 PM
Silver-Bolt's Avatar
Very lean! I wonder if the chip is over riding the ability to compensate for altitude? What is your elevation?
Old Nov 12, 2002 | 02:24 PM
thundergod's Avatar
My altitude is 5300, about a mile high. My friend bought the same chip for the same pulley from the same tuner. Only diference is his is a 2002 and mine 2001. His A/F is at 11:1 12:1 from 4500 RPM to 5500. Any chance that me not having the pulley on could be making it run lean. Should it have not run rich without the pulley?
Old Nov 12, 2002 | 02:51 PM
soap's Avatar
OMG does that barometer suck.
--Joe
Old Nov 12, 2002 | 02:59 PM
02Thunder's Avatar
--Joe
Wow, I just noticed that! 24.55??? High altitude sucks! Glad to have the low 30.00s down here.
joe
Old Nov 12, 2002 | 03:22 PM
soap's Avatar
joe
Ya go to Cecil and you will see over 32.........damn I wanna make a road trip before that track closes
--Joe
Old Nov 12, 2002 | 03:35 PM
02Thunder's Avatar
Yeah, combine that corrected altitude, with the fact that Cecil is downhill from the 60' mark out, and no wonder people love to race there.
I was there for the ModShootout in June, that track is nice. Good prep, and great air.
joe
