Question about pulley install
Old Nov 10, 2002 | 01:22 PM
JRocksSVT's Avatar
Is there another way to lock the motor other than the actual motor lock tool because I dont have one and I thought maby there is another way to lock it........thanks for the info
Old Nov 10, 2002 | 01:53 PM
SLVRLTNG's Avatar
JRocksSVT,
you could pobably just use a box end wrench on one of the torque convertor bolts and sort of "wedge" it to a stop so it will hold the motor locked.......JR
Old Nov 10, 2002 | 02:46 PM
JRocksSVT's Avatar
thanks......anybody else
Old Nov 10, 2002 | 03:13 PM
SVT_FL's Avatar
You could make your own by taking a scrap piece of metal about 4in long with a bend in the middle. Then drill a hole large enough for the converter bolts to go though. If you saw one, it would be real easy to make.
Old Nov 10, 2002 | 03:57 PM
SVT_KY's Avatar
Or you can use strapping banding wiht the holes in it ...
Old Nov 12, 2002 | 03:04 PM
thundergod's Avatar
You can get some muffler strapping,double it up and oval out the holes a little more for the bolts to fit
Old Nov 12, 2002 | 03:54 PM
brap's Avatar
I stuck a wrench on one of the fly wheel bolts then starting torking on the bolts on the pulley, eventually the wrench on the flywheel will catch on something and wont move anymore.
