Big Wheel Problem
Old Nov 10, 2002 | 02:27 PM
lowendgenerator's Avatar
Question Big Wheel Problem
Hey guys, I got one for ya. Ive got a 2000 L, and the stock original F1 finaly died, on the rim, on the truck. I followed all the instructions for removing the rim: taking off lug nuts, jacking truck up...but I cannot, for the life of me, remove the wheel from the truck. Am I forgetting something? Is there some super secret clip? Should I apply heat? Ive tried WD40 and other anti-seize lubes, nothing is working. This really sucks, cuz Its in a parking lot and I dont want it to get towed.
Any wisdom would be greatly aprreciated.
adam
Old Nov 10, 2002 | 02:32 PM
superfords's Avatar
it's probably just seized onto the hub.
try hitting the tire with the palm of your hand (HARD) alternating from one side of the tire to the other. you know like BANG BANG BANG BANG or LEFT RIGHT LEFT RIGHT. follow me? not trying to be funny here, its just sortof hard to describe how to hit the tire
also if this doesn't work, you can get a rubber hammer and hit the back of the rim around the lip.
good luck.
later,
chris
Old Nov 10, 2002 | 02:34 PM
RTKILLA's Avatar
good luck.
later,
chris
I would kick it insted, allot easier on your hands!
Old Nov 10, 2002 | 02:40 PM
SpankDog's Avatar
Banned
KICK IT! I had to do the same thing to mine.
Old Nov 10, 2002 | 02:53 PM
smknjoe's Avatar
are you using the adapter socket that is probably in your glove box?????
Old Nov 10, 2002 | 04:18 PM
superfords's Avatar
True, True. I'm used to working on a lift, so for me to kick it I'd be doing some Bruce Lee type moves. I'm not that flexible
kicking like this should work fine too.
later,
chris
Old Nov 10, 2002 | 04:29 PM
cyntaxx's Avatar
depends if you've mastered the "one-inch punch" use it!
Old Nov 10, 2002 | 06:58 PM
I know nothing of this special adapter. The nuts are off. I think it is siezed. I was even beating it with the full size spare. The tire is completly flat, so punching it wouldnt to much good, but I know what you mean by alternating left and right. Im gonna go beat on it some, its good for getting out my agressions.
thanks again.
adam
Old Nov 10, 2002 | 08:57 PM
svt4rd's Avatar
I use a rubber mallet to hit the rubber part of the tire with usually works
Old Nov 10, 2002 | 10:31 PM
Lightning Boy's Avatar
Just plane and simple: kick it. The the heel of your foot on the top part of the rim with a quick hard shock, it'll come loose. Though do make sure the truck wont fall of the jack or jackstands when you do kick it.
Old Nov 10, 2002 | 10:57 PM
FXDX's Avatar
A four lb. dead-blow hammer to the rim should do it. (Protect the rim with a rag or piece of rubber belting, truck mud flap, etc.)
Old Nov 11, 2002 | 10:55 AM
DarrylChicago's Avatar
Put the lugs back on leaving it a couple of threads loose. Then drive the truck forward about 10 or 15 feet then back. Jack it back up remove the lugs, and the wheel will fall right off. Then put some bearing grease on the hub so it doesn't happen again.
Darryl
Old Nov 11, 2002 | 12:41 PM
SCOTTSBEATER's Avatar
take all the lugs off all the wheels. Lower vehicle and do donuts until all the wheels fall off.
Old Nov 11, 2002 | 03:10 PM
LOCOSVT's Avatar
What DarrylChicago said...when these things freeze up, it takes a lot of weight to break them loose sometimes. If it still doesn't work, back VERY gently into one of the concrete curbs at an angle. Don't leave the lugs too loose or you'll risk flattening the threads.
Old Nov 11, 2002 | 03:23 PM
RTKILLA's Avatar
later,
chris
HAHAHAHAHAHA
