Bassani high flow cats
Old Nov 10, 2002 | 08:03 AM
Silver-Bolt's Avatar
Who has the best price on Bassani high flow cats? Or does anyone else make a bolt-on high flow cat for the L? I need cats and mid-pipes to match up to a Bassani cat-back. I am running stock manifolds.
Old Nov 10, 2002 | 08:23 AM
99svtlightning's Avatar
I had the bassani high flow cat pipes and they sound great. I had to cut it up to fit the long tubes, but the cats flow well and sound mean. Check w/ JLP for pricing.
Old Nov 10, 2002 | 12:20 PM
Thank you. Any others?
Old Nov 10, 2002 | 01:52 PM
dionisio's Avatar
Registered User
Cats
I was considering them but Bassani told me that they don't guarantee they will pass the smog test. If that is the case why waste the money. Just put straight pipes. If they don't pass, why even bother.
Old Nov 10, 2002 | 04:00 PM
I need a bolt on replacement for my existing mid-pipes. Couple of years ago when I had a Magnaflow 12468 installed the shop cut off the factory muffler and welded on the Mag. Now I want to replace the Mag with the Bassani cat-back. If I cut the Mag off there isn't enough pipe left to attach the Bassani. Since the pipes are part of the cats I thought why not just replace them. Muffler shop won't touch that unless they truck is 5 years old or 50k miles. Neither applys. That's why I hope to find a bolt on solution to do it myself.
Old Nov 11, 2002 | 08:01 AM
BlueOvalBolt's Avatar
Try www.houstonperformance.com
