Big Brakes are on!
Old Nov 9, 2002 | 07:13 PM
Silver-Bolt's Avatar
Big Brakes are on!
Check out my gallery under suspension. Finally have the bad boys on. Initial road test was very impressive. Me likey!
Old Nov 9, 2002 | 07:27 PM
speedfreak's Avatar
Nice
$2,600 big ones...ouch
Old Nov 9, 2002 | 07:31 PM
rscoleman's Avatar
Nice ...
Old Nov 9, 2002 | 07:32 PM
Did mine a little different. Made my own hubs, picked up bits and pieces when I could find them. I am in them a whole lot less than that. Lots of my time and effort but I don't charge myself much.
Old Nov 10, 2002 | 04:12 PM
Well after bedding the new rotors and pads these things are awesome. As soon as we get some dry weather I plan to disable the ABS and really see what they can do.
Old Nov 10, 2002 | 04:28 PM
SpankDog's Avatar
Banned
Wow Nice
Old Nov 10, 2002 | 05:03 PM
Spike Engineering's Avatar
You should post the results of stopping distances from 90mph - 0 with:
ABS On
ABS Off
Old Nov 10, 2002 | 06:39 PM
Spike,
Great idea. Just need dry weather, which doesn't look good for the nxt two weeks.
I have done that exact test in a car (Toyota MR2). 5 out of 5 times the non-ABS stop was shorter.
I am not a big fan of ABS. I think it has it's place but on a performance car it should have a switch to turn it off.
Old Nov 10, 2002 | 08:31 PM
thepawn's Avatar
How'd you get the dustshield to fit? Looks like you bent it? Dosn't tap on a turn in?
Daniel
Old Nov 10, 2002 | 10:51 PM
You should test it in the rain too, but maybe only 55 - 0 in a wide parking lot. In that test, I would expect ABS to outperform your touch.
Also, in dry weather, test high speed stops back to back and count how many times before you start to feel a soft pedal.
Old Nov 10, 2002 | 11:36 PM
action 911's Avatar
Unhappy
All I can say is, NICE, VERY NICE. Can I drive down from Puyallup to see if they will fit on my truck with the 22's that I have???? (Foose Sprank) Please, Please. I have been on the phone with Stop Tech, and everybody else with big brake kits. No one knows if my wheel combo will work.
Herb
Old Nov 11, 2002 | 12:44 AM
Herb
Make a template from the inside of the wheel to the stock rotor surface with construction paper and mail it to them.
Old Nov 11, 2002 | 09:24 AM
Pawn, the rotors are close to the sheilds but no contact at all. I had to tweak the lower leading edge by about a 1/4" was the only bend made. Everything else is factory.
Action, you are more than welcome to come down and try a wheel. See if we can cordinate a time that works.
Old Nov 11, 2002 | 09:55 AM
NeedFourSpeed's Avatar
Very Nice -
Did you do all four wheels?
Old Nov 11, 2002 | 10:28 AM
Ruslow's Avatar
ABS system will stop longer than non abs because for the operation of abs the wheel and tire HAVE to stop for and instantthus slidding you want to be rite at the point of lock up but not locking or using the abs.Stan
