A/F's----survey
Old Nov 5, 2002 | 02:04 PM
Flying Mofo's Avatar
Banned
Yup...
12.0 with a chip and k&n drop in
Will go 11.5 with pulley/chip/air intake kit for street with 91 octane
Will go 12.0 with same above mods with 104 octane for race program.
Old Nov 5, 2002 | 02:10 PM
rscoleman's Avatar
Don't know the A/F, I run a 3# without a chip.
Old Nov 5, 2002 | 03:53 PM
lightning856's Avatar
Im at 10.6 at peak HP
Old Nov 5, 2002 | 06:07 PM
triclexusis300's Avatar
yep after a un named tuner couldn't burn it right drove 2 hours
to a dyno shop and had a chip burned by the dyno tuner on site.....12.0a/f
Old Nov 5, 2002 | 08:11 PM
Odin's Wrath's Avatar
Yes
Old Nov 5, 2002 | 08:24 PM
L iminator's Avatar
A/F
A tuner who sells you a mail order chip filter and pulley, should be able to quote the A/F at any given RPM. If you mod any after that, all bets are Off.
Old Nov 5, 2002 | 08:28 PM
L iminator's Avatar
Oh Yeah, NO!
Old Nov 5, 2002 | 08:58 PM
Rob_02Lightning's Avatar
Nope, not yet ,
but then again, I never use a rubber either
Old Nov 5, 2002 | 09:08 PM
LTNSTKU's Avatar
I dont know what air fuel ratio it converts to but I checked the O2 voltage with my autotap
side 1 = .900 volts
side 2 = .950 volts
with an 8# pulley
the voltage was steady for the entire pass and no detonation
Old Nov 5, 2002 | 09:18 PM
Crazyone's Avatar
Yes, 11.45:1 at WOT at redline.
From 3500rpm on it is at or below 11.9:1
Brandon
Old Nov 5, 2002 | 10:40 PM
andy_cain's Avatar
AFR#'s
http://talon.svtlightnings.com/forum...s=&postid=8726
I don't know how to add the picture...this was todays Dyno
Old Nov 5, 2002 | 10:58 PM
cyntaxx's Avatar
Old Nov 6, 2002 | 01:40 AM
SVT150's Avatar
Yup, 11.5
Old Nov 6, 2002 | 02:25 AM
red gen 1 94's Avatar
I have had my chip reburned several times because i wanted to get more and then more out of my truck even though JDM warned me not to.......Little test here! I ran my truck at the local 1/8 mile track......I had 5 JDM tuned superchips 4 of which were for my truck.....the other for a good customer of mine. I made 30+passes on nitrous and no problems on any of the 5 programmed chips.......The chip i ran my best ET on wasnt programmed for my truck......ran his chip on nitrous (his truck not having nitrous) I sent the chip directly to him without changes and it detonates on him...No NOS .......It was just the chance i took.....If you are willing to take chances and try to pull out "just one more tenth" then you should be willing to take the punishment if it happens.....All this BS bout autotap is nonsense! If you believe autotap then you might as well just buy a chip from the classifieds that matches your box code and run the crap out of it.....Autotap is totally a bunch of garbage !
Old Nov 6, 2002 | 03:36 AM
I8ACAMRO's Avatar
Yes, 11.4 at 5500rpm
