My bolt is "eating oil? WTF?
Old Nov 4, 2002 | 02:37 PM
brasil's Avatar
Chris, I jsut noticed the oil issue now. I hswitched to synthetic at 18500 miles
Old Nov 4, 2002 | 02:42 PM
01Lightning's Avatar
brasil, when did you install the crankcase breather?
Old Nov 4, 2002 | 02:43 PM
brasil's Avatar
I installed the breather cap at 10000 miles when I put the chip in.
Old Nov 4, 2002 | 03:44 PM
LIGHTNINROD's Avatar
Originally posted by JBLsilver01
After I fill it with 6 quarts it will be in the middle on the dipstick btwn min and max. After i start it and let it idle for 30 seconds to fill the filter, and shut it off - it reads MIN. So I add half a quart. 6.5 total. I use a breather cap and don't get oil in my intake.
You could check your plugs for any signs of burning oil..........
JBL: You should fill(not quite to the top) the filter before you screw it on and use 5.5-6 qts total(I use 6 qts.). By checking your oil level after letting it run for a few seconds, you are not getting a true, accurate oil level. You should let it sit for at least an hour and I let mine sit overnight before I check the level. With 6 qts in and waiting overnight, my oil will show midway between min. and max.
Dan
Old Nov 4, 2002 | 04:46 PM
Fast Gator's Avatar
Thanks for chiming in Dan, I thought I was the only one around here that puts oil in my filter before installing (approx 1/2 to 3/4 quart of oil in filter)
Old Nov 4, 2002 | 06:19 PM
GN1270's Avatar
If the filter was loose, I would notice oil in my garage floor!!
Wrong, well could be.. When your truck is parked in your garage, there is no oil pressure, or low oil pressure when you go to start it. You could be leaking oil out of a loose filter while @ WOT when the pressure is at its highest...Hope his helps......Scott
Old Nov 5, 2002 | 01:56 AM
JBLsilver01's Avatar
Thats what I'm saying - is I fill it up with 6.5 quarts, and I'm just filling the filter by cranking the engine over. Either way works, and you still get 6.5 quarts in.
and I've had my breather cap on for probably 10k miles and do not have oil in the intake. I left PVC alone - no fuel separator.
Old Nov 5, 2002 | 07:33 AM
Why are you people putting in 6.5 qts of oil? The book says to use 6 qts.
6.5 qts is way too much.
