Swanson Air Filter Kit
Old Nov 2, 2002 | 12:21 PM
I8ACAMRO's Avatar
Installed Swanson filter kit, chip, and 4# pulley and dynoed 411.4 RWHP and 502 RWTQ
Old Nov 2, 2002 | 01:08 PM
svt360's Avatar
welcome to swanson land sweet numbers,i have the same setup!!
Old Nov 2, 2002 | 02:49 PM
Skip's Avatar
Seanson filter kit
Mine was good for 5 HP over stock airbox with a 4 inch hole cut in the bottom. By far the best filter setup on the market!
Old Nov 2, 2002 | 02:53 PM
Skip's Avatar
Swanson filter kit
Spelled Swanson wrong in last post! I am too stupid to live!! Skip
Old Nov 2, 2002 | 03:31 PM
I8ACAMRO's Avatar
I had no intention on replacing the after market system I had, but this kit is such a great setup I couldn't resist.
Old Nov 2, 2002 | 04:06 PM
Fast Gator's Avatar
Re: Seanson filter kit
Please clue the rest of us why this is the "best filter setup on the market!"
Iam allways interested in learning something new
Old Nov 2, 2002 | 04:29 PM
Skip's Avatar
Swanson filter
The reason that I believe it is the best is because of the way it is constructed and the way it does not interrupt air flow. It mounts in the stock holes and the filter is supported on both ends. It has a shield to keep hot air from exhaust manifolds from getting to the filter. The shield also prevents fan wash . Now the real good part. Billet adapter is same size as the inside of the air meter. (mot filter kits that I have seen are a bit smaller than the air meter) Air charge temp sender is not disturbing air flow as it is off to the side with ports leading to and from it. It looks like it came from the factory. Mine has a black anodized adapter ring along with a black anodized filter bracket. It even has these neat little machined adapters that go into the holes used by the stock air box. I know, everyone will say it is just a filter, but it is really a neat piece! It works great too. I really did pick up 5 HP at the rear wheels on Dannys dyno. Looks great and works great! What else could you ask for. It is a great mod. Skip
Old Nov 2, 2002 | 05:17 PM
superfords's Avatar
looks nice, but i like the longer powerstack style filters better (not compensating here )
am an very curious about the IAT sensor, seems like overkill to say the least to go to the trouble of mounting it like that. this sensor doesnt interrupt airflow, it is tiny.
could you show some pictures of the "ports" goint to and from the sensor.
again, looks cool though.
I wonder why nobody makes cold air boxes out of plastic, may not look as nice, but would SEEM to be cheaper and could be made into whatever curved shapes necessary to fit closely around other components in the area of the filter. seems like an injection moulded (or however it is that they make plastic stuff) "bucket" or air box would work great and have the added benefit of not transfering heat.
later,
chris
Old Nov 2, 2002 | 06:08 PM
I8ACAMRO's Avatar
Chris, I have a pic in my gallery that might show you what you want to see. I would post it, but I'm new to all of this and having a few problems.
Old Nov 2, 2002 | 07:32 PM
LIGHTNINROD's Avatar
It does look nice. I'd get an Outerwear 'sock' to keep your filter clean longer.
Dan
Old Nov 2, 2002 | 09:29 PM
LightninSVT's Avatar
That is sweet looking! Do these guys have a web site?
Jon
Old Nov 2, 2002 | 09:34 PM
Odin's Wrath's Avatar
Jon
http://www.swansonperformance.com/
Old Nov 2, 2002 | 10:48 PM
Man, there website isnt very informative. I don't even see the air kit on it?
Am i missing something?
Old Nov 2, 2002 | 11:02 PM
I8ACAMRO's Avatar
The kits aren't on the website yet. You can call or e-mail for info
Old Nov 2, 2002 | 11:24 PM
SVT150's Avatar
I have the same setup, and I can testify that it put over 30rwhp from my after market air intake (Valont) to this sweet setup!!!
I have dyno results to prove the difference as well as a fellow L brother.
