Suspension....Need help from any of you 3/4 drop guys
Old Oct 30, 2002 | 06:07 PM
Rayden's cloud's Avatar
Hey anyone with the 3/4 drop kit know the correct endlinks (front/rear) to get that will position the sway bar back to stock? Also where might I be able to get some polyurethrane bushings for the sway bar?
Old Oct 30, 2002 | 06:20 PM
Chikenears's Avatar
Rayden's Cloud,
Measure the actual drop that the truck is lowered and use that measurement to apply to the length of the new endlinks. For instance, if the truck was lowered 3" in the front, measure the stock endlinks and subtract 3" from that, and that will determine the length of the new endlinks. Pep Boy's sells a variety of end links and probably has the size you need.
As for the rear, the same applies. They are dog bone style and Pep Boy's does not sell them. I cut mine to the appropriate length and welded them back together.
Hope this helps,
Tim
Old Oct 30, 2002 | 07:26 PM
Originally posted by Chikenears
Rayden's Cloud,
Hope this helps,
Tim
Thanks for the advice man...What about the urethane bushings that go on the sway bar..From what i hear that helps stiffen things up also..where might i be able to find those?
Old Oct 30, 2002 | 08:00 PM
Chikenears's Avatar
http://www.energysuspension.com/endl.html
Old Oct 30, 2002 | 09:20 PM
Spike Engineering's Avatar
Be careful of the steering linkage.
Old Oct 30, 2002 | 09:41 PM
Chikenears's Avatar
Spike,
Would you mind elaborating on the steering linkage? I've been wondering about this since I've seen similar posts with no definite explanation. Or at least point me to some post where it has been explained?
Thanks,
Tim
Old Oct 30, 2002 | 10:08 PM
Tim,
The times I have pointed it out have only been when someone is told to cut the front endlink 3" without regard to the rest of the moving parts in that area. The problem is that a lot of moving parts are getting closer and closer to each other.
If you lower the front 3" (huge drop) and then cut the endlink for the swaybar 3", has anyone checked whether or not the steering linkage binds thru the suspension's range of motion, while turning the wheel? Without checking it, it could be a problem. Maybe there isn't a problem, but the consequences could be dangerous.
I'm just pointing it out.
Old Oct 30, 2002 | 10:18 PM
Chikenears's Avatar
Spike,
Thanks for the reply. I don't know of anyone who has checked it but that would be an excellent idea.
Do you have any ideas on how to check something like this since the truck would have to be moving over bumps at the time or at least be subjected to up and down extreme movement while steering?
I would love to see someone address this issue and post on it.
Tim
Old Oct 31, 2002 | 07:16 AM
Spike,
Tim
I second this....Anyone??
