Pauls Smooth Intake Tube
Old Oct 25, 2002 | 11:46 PM
Ak.Silver2K's Avatar
Has anyone installed his tube to JL's ram air cold airbox setup?
I was wondering if any modification was necessary to get it to fit.
Thanks,
Mark
Old Oct 25, 2002 | 11:54 PM
JeffsLightning's Avatar
I have heard maximum modification is needed...Not for me
Old Oct 26, 2002 | 02:11 AM
VINNIE's Avatar
go here
Soap has one on his.
http://www.nloc.net/forum/showthread...5&pagenumber=3
Old Oct 26, 2002 | 12:34 PM
soap's Avatar
Re: Pauls Smooth Intake Tube
Thanks,
Mark
Ya you need to modify it.......if you want email me and I will try to explain in greater detail.
--Joe
Old Oct 26, 2002 | 04:35 PM
ShadowLightning's Avatar
That's JL's airbox setup correct? I have the same setup in my truck, and am ordering the smooth intake tube, soap is it a major job to do?
Old Oct 26, 2002 | 05:39 PM
soap's Avatar
No it is not bad.....I cut off like an inch of the tube. Then I had to cut off/level out the top of the air box because it was hitting underneath my hood. The smooth intake tube lifts the air box up quite a bit. Oh I also had to shave off some of the bracket for the radiator overflow tank.
Hope this helps......
--Joe
Old Oct 26, 2002 | 08:22 PM
LIGHTNINROD's Avatar
I have PSP's Fast Air kit and I had to take the bracket off of the eng. stud to raise the 'box' about an inch for the MAF angle to fit the new smooth pipe. I put a larger diameter washer on the stud and ran the nylock nut back on so the washer would hold the bracket tight against the eng.
Dan
Old Oct 26, 2002 | 11:05 PM
Soap
Thanks for the reply
Mark
