paging silver-bolt
Old Oct 13, 2002 | 02:15 PM
cabraco's Avatar
paging silver-bolt
Saw that pic of the piaa fog light conversion you did. How tricky was that, any cracking problems, what color light does that give off?
Old Oct 13, 2002 | 07:36 PM
Silver-Bolt's Avatar
It was pretty easy. They are PIAA 959 lower mount lights. They are an 85watt projector fog light. They give off a yellow light. They are not a long range driving light. I have a set a PIAA 510's for that. I had to do a little Dremel work to the factory mounting location. None of which is visible and none of it affected going back to stock. I then took apart the factory lights to unplug the wiring pig-tail. I installed the factory pig-tail on to the PIAA lights so the plug into the factory wiring. I had to enlarge the factory mounting hole (99-00) to accomodate the larger PIAA mounting stud. That's about it.
Next up is installing the PIAA 510's into the outside corners of the lower grill
