MT ET Streets
Old Oct 8, 2002 | 10:16 PM
CDub's Avatar
MT ET Streets
I bought a pair of MT ET Streets and I live about 3 miles from the nearest strip. is it OK to drive on them to the strip or go through the pain in the a$$ and install them at the strip?
Also, anyone have suggestions for length of burnout prior to launch with these tires?
Old Oct 8, 2002 | 10:18 PM
blowntruck's Avatar
How about driving them 25 miles? Safe ? Or do it at the track?
SVT_KY's Avatar
Under clear skies, 30 lbs ... Sure .... Warm 'em up a LOT ...
Old Oct 8, 2002 | 10:23 PM
soap's Avatar
I totally agree
--Joe
Old Oct 8, 2002 | 10:27 PM
CDub's Avatar
What kind of 60' times are you getting with ET's?
Old Oct 8, 2002 | 10:37 PM
blown318's Avatar
Thumbs up
Chit, in the summer when i had et streets.... i used to drive on those things everwhere. They would be put on friday and stay on until sunday night sumtimes monday. As long as there aired up there not bad to drive on at all.
Old Oct 8, 2002 | 10:38 PM
Blown93's Avatar
I drive mine all over town, all the time............. Warning Warning totally avoid water or rain.. good luck
Old Oct 8, 2002 | 10:44 PM
CDub's Avatar
what pressure do you run on the strip? I have heard anywhere from 12-15psi.
Old Oct 8, 2002 | 10:59 PM
soap's Avatar
Mid 1.7's on stock convertor.
--Joe
Old Oct 8, 2002 | 11:00 PM
soap's Avatar
You heard wrong.......that is too low IMO.
I start with 16 psi cold....after my first burnout I have to lower them back down to around 18psi........than I am good to go.
--Joe
Old Oct 8, 2002 | 11:12 PM
CDub's Avatar
thanks soap. I'll try it out this Friday.
Old Oct 9, 2002 | 08:12 AM
soap's Avatar
Good luck
--Joe
Old Oct 9, 2002 | 12:49 PM
Fast Gator's Avatar
I found out 15 is too low
Chitty 60'
1.90
Old Oct 9, 2002 | 01:21 PM
SILVERLIGHTNING's Avatar
MT ET Street- 26x11.50-16
Experimenting
First run was a personal best
12.880@106.13__60=1.940. 1700rpm, (Squeeze the gas) spun the tires-18psi
Second run was a hot lap
13.015@105.39__60=1.995. 1500rpm, (Mash the gas) spun like a top
Third run was a good cool down
Lowered the pressures to 16,Launch @ 1400,(Mash the gas) Hooked up better! Results: 12.798@106.45__60=1.894.
Fourth run was Cold. Real COLD. 50degrees
12.711@106.71__60=1.839. 1200rpm,(mash the gas) Felt good, still spun the tires.
The lower I launched, the faster I got!
Wish I had another few rounds
Also of note: the more I smoked them the better they worked. I didn't make but a little wisp of smoke on the first two burnouts. I probably over cooked the tires on the final burnout, but I don't think it hurt me any.
I think I "left some on the table". I can do better!
Fred.
