Launching on Slicks
Old Oct 7, 2002 | 01:30 PM
Fast Gator's Avatar
maybe I was asking for a blue bottle of beer
Old Oct 7, 2002 | 03:16 PM
Rob_02Lightning's Avatar
Originally posted by Fast Gator
hold the rpm's at 2500/3500, till the smoke starts to boil
pull to the line in drive and bring the rpm's to 2500 for a starting point, go on the last yellow Yell, "Who's your daddy" as your going thru the traps
LMFAO @ Fast Gator
Old Oct 8, 2002 | 10:19 AM
tommylightning's Avatar
As far as tire pressure, don't go under 16psi. I found that 16psi worked best for me(when I was running the ET streets). While doing your burnout, keep it in drive (overdrive off) and get the Rs up and let it shift into 3rd. Run until you see smoke then run about 5 secs more. I would run about 1000 rpms when getting ready to launch on the stock converter. If the track does not take the shock of the tires well (not very sticky) then bring the Rs up some more. It seems to be best to shock the tires by not bringing the converter to the top of the stall. But this will be harder on the grip to the track. You will need to practice to see what the track will take. When I bracket race I bring the converter almost to its stall so that the tires do not get shocked and helps with traction. This will not help with the best ETs.
Old Oct 8, 2002 | 12:40 PM
SILVERLIGHTNING's Avatar
Thumbs up Tonight's the night
Thanks Tommy, Sal, Gator, & all
We will find out tonight what works.
The weather is great: 30.31 barometer, 50 degrees @ race time, and low humidity. Cool Canadian air should make for record breaking times.
Thanks again.
Fred.
Old Oct 9, 2002 | 02:30 AM
Thumbs up Results from Atco,NJ
Old Oct 9, 2002 | 02:36 AM
First run was a personal best
12.880@106.13__60=1.940. 1700rpm, (Squeeze the gas) spun the tires-18psi
Second run was a hot lap
13.015@105.39__60=1.995. 1500rpm, (Mash the gas) spun like a top
Third run was a good cool down
Lowered the pressures to 16,Launch @ 1400,(Mash the gas) Hooked up better! Results: 12.798@106.45__60=1.894.
Fourth run was Cold. Real COLD. 50degrees
12.711@106.71__60=1.839. 1200rpm,(mash the gas) Felt good, still spun the tires.
The lower I launched, the faster I got!
Wish I had another few rounds ;-)
Also of note: The more smoke I made, the better we hooked. Not that I put on a smoke show, but the first two runs were barely a puff. The last run was probably a little too much smoke, but I don't think it hurt any.
Thanks Tommy.
Fred
Old Oct 9, 2002 | 05:31 AM
Fast Gator's Avatar
Very Nice
Wish my 60' times where like yours but maybe tonight I'll give it a shot
With those 106 mph times it indicates that you got the power
Congrats
Old Oct 9, 2002 | 08:57 AM
Go Fred, Go Fred, Go Fred! Great times buddy. You are really working into the 12s now Your mph is great for only having a 2# lower pulley! Next time try 1100 rpms and easy on the gas. If you look at your 60fts they were better the more you shocked the tires. Hope to meet up at the track soon. My L will be completed today. Just have the electric fan and exhaust to finish. I may go to Atco tomorrow.
Old Oct 9, 2002 | 01:06 PM
Headlight Removal Mod
Headlight Removal is good for one mile per hour.
I like to think so, anyway!
Old Oct 9, 2002 | 01:24 PM
DEIMATT's Avatar
Iam still in the learning curve.........
But this is what I do:
Start at 15psi
pull out of the water and start your burnout in low gear (1)
WHOS YOUR DADDY..that is the funniest thing I have read on here in a while..LMAO..Nice one Gator..WHOS YOUR DADDY!!!
Old Oct 9, 2002 | 03:06 PM
Harley#356's Avatar
nice times fred! i gotta see ya run one of these days
so, how far do ya wanna get? mid-low 12's? or 11's
Old Oct 10, 2002 | 02:27 AM
Everything is cool right now!
I think I'm going to duct tape the hood shut
Old Oct 10, 2002 | 05:22 AM
Fast Gator's Avatar
make sure you use that nascar tape
Old Oct 10, 2002 | 12:56 PM
Exclamation See you next weekend!
I'll bring a roll to Englishtown next weekend!
