2" Shackle Question?
Old Sep 24, 2002 | 02:14 PM
Silver 2002's Avatar
What's up fella's, I need a little help with a couple of questions I have. I was considering buying the 2" Shackles for my L. I really do not want to mess with the front suspension. If you put on the 2' shackles will it make your L completly level. It looks like to me 2' would make it sit lower in the back. This could just be my eyes playing tricks on me. I'm just wondering will it make it completly level. If any of you have pics of your L's with just 2' shackles please post them. Also, this may be a stupid question but if I put on the shackles and dont like the way it looks, can you take them off and get your truck back to stock position. Is this possible?Thanks guys.
Old Sep 24, 2002 | 02:47 PM
Skank Dog's Avatar
I installed the belltech shackles and it makes the truck sit level. If ya dont like it, just remove the belltech's and reinstall your stock one's. Takes all of about 30 minutes.
topsy's Avatar
On my truck, using the 2" shackles, it didn't lower it a full 2". My truck has a slight rake to it still, so it is not perfectly level.
You can easily put the stock shackles back on if you want. It's easy to do, I could probably do the swap in 10 minutes.
Old Sep 24, 2002 | 02:49 PM
01Lightning's Avatar
I got about a 1.5" drop from mine. Made the truck perfectly level
Before Shackles:
After Shackles:
Old Sep 24, 2002 | 03:16 PM
Highlander nm's Avatar
I had a question also
I was thinking about the rear shackles. I found them for $50 on stylin concepts, Where is the best place and how much to get a kit that will give the L a 3/4"- 1" drop in the front. I like the 1" but i don't want it any lower at the front.
Any info would be appriciated.
Thank's
Old Sep 24, 2002 | 03:53 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
shackles only.
shackles, 2" springs up front, and the 'Dog mod.
Old Sep 24, 2002 | 05:04 PM
EXCITED's Avatar
western chassis
a little tip
B4 you tighten the shackles up use floor jack and jack front end up = transfer weight to rear and then tighten the shackles= full 2 inch drop this way
i went wieh western chassis for under 37.00 to the door.
western chassis 2 inch drop shackles
quote:
Originally posted by FastSVT
What brand are the shackles you used. Thanks
i went with the western chassis 2 inch shackles had to grind i/8 inch off of the spacker tube work great and they where cheap.
western chassis 2 inch shackles are on
I got the drop shackles,Western Chassis on in a record 1 hour 15 mins this morn=SUN.Had to cut 1/8 inch off the bottom hanger bushing steel sleeve,they fit really good , considering I, only spent $37.00 to my door on them..
They look great and ride well too , readjusted the{ MAC tips } the body went a little lower down on them,they look good now also.
Only one really bad busted Knuckle due to my hand slipping off the vise, cut knuckle to the bone ouch...=BLOOD SWEAT AND GEARS, LOL
Again thanks for the input/advice,it really helped
dont forget to align your headlights..
Old Sep 24, 2002 | 07:00 PM
Rob_02Lightning's Avatar
Don't pay more than $29.00 for the shackles.
If you need a link, e-mail me
Old Sep 24, 2002 | 07:29 PM
Wow, were did u get the shackles at that price from? The cheapest i have found them is $50
Old Sep 24, 2002 | 07:36 PM
I was looking for at the ground force site and is the N9002 p/n the kit that fits our trucks?
Old Sep 24, 2002 | 07:37 PM
02Thunder's Avatar
Rob... you got mail!
joe
