QUICK HELP!!! How many quarts for transmission?
Old Sep 22, 2002 | 04:40 PM
Weedo's Avatar
Just put in a Line Mod Valve with my buddy in his '01 with a deep 4x4 pan.
How many quarts???
thanks!
Old Sep 22, 2002 | 05:05 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Buy 7 quarts. Start by using only 5 then work the gears up and down a few times, check fluid level. Drive it gently for a few minutes, check fluid level. Add as necessary.
Old Sep 22, 2002 | 05:14 PM
Weedo's Avatar
Thanks Bob!!!!!!!!
Old Sep 22, 2002 | 07:18 PM
JeffsLightning's Avatar
I just drained my 01. I drained the torque converter and I have a B&M pan..It took 16 quarts...If the 01 was built before 8/01 it will have a TQ drain plug...
Old Sep 22, 2002 | 07:20 PM
brasil's Avatar
Weedo, mine took a total of eight. I started with 6 1/2 and had to finally work to eight. Remeber that when the engine is cold you will get a much lower reading than when hot. Drive it for about 20 - 30 miles, that is when the tranny has reached the optimum temperature, and you will get a more accurate reading.
Old Sep 22, 2002 | 07:49 PM
2Cool's Avatar
Second the 8 thing, just did the FT valve body and the 4x4 pan. 8 put it dead nuts in the Hot range of the dipstick.
Keep in mind that you aren't draining the convertor, so you aren't replacing all of the tranny fluid, only the most of it which happens to be in the pan.
Old Sep 22, 2002 | 08:08 PM
BADBOLT2's Avatar
Weedo,I'm going to the track Fri.Have you had the "Chebbie"out yet??Let me know if you wanna go!
