two 12's??
Old Sep 21, 2002 | 03:56 PM
YtDiamond05's Avatar
two 12's??
are there any boxes that will fit 2 12's in the L that i can get offline??? i want the seats to be fully functional and have the armrest be able to move up and down. ive seen the boxes for 10's but havnt seen 12's or where to get them. yes i did a search by the way, i just found info on 10's.thanx for the info.
Old Sep 21, 2002 | 11:43 PM
ttt
Old Sep 22, 2002 | 12:23 AM
2001SilverL's Avatar
theres really not that much difference between 2 10's and then 2 12's i have 2 10's and its sounds pretty damn good
Old Sep 22, 2002 | 12:40 AM
mecca's Avatar
With 2 12's you just won't get the high-pitced bass you get from the 10's. Also, good luck finding a sub that will have enough space to work behind our seats...
-Mike
Old Sep 22, 2002 | 12:42 AM
InS0mNiAc's Avatar
I believe that blaupunkt (probably wrong) has just introduced a sub that is less than 1 inch thick! Its a 12 inch sub that needs close to no room to move air around, the mounting deph is amazing. I wish I could remember where I read it, I think its 300 watts rms, when tested it sounded just as good as a full size 12 inch sub, so if you want the 2 12's do a search online for those!
Upon further research, it is blaupunkt, they are called the overdrive saucer subwoofer. They range at about 250 a piece and come in at 400 and 500 watt's respectively. They actually come in 10, 12, and 15 inch sizes ranging from 200 for the 10's, 400 for the 12's, and 500 for the 15's rms! They range betwen 230 and 350 a piece, not bad for the technology. click for more info
Old Sep 22, 2002 | 04:08 AM
J15BIG's Avatar
I know motoXracer21(jason) has 2 12s in his truck. They hit damn hard! Maybe he will chime in..
Old Sep 22, 2002 | 04:21 AM
clonetek's Avatar
2 12's sounds pretty good... but i'm biased, or something..
more pics here: https://www.f150online.com/galleries...iew.cfm?num=63
Old Sep 22, 2002 | 05:13 AM
InS0mNiAc's Avatar
thats one hell of a setup for a single cab truck, you get a lot of air movement with that seats far back?
Old Sep 22, 2002 | 08:10 AM
Fast Gator's Avatar
I bet it blows his hat off
Old Sep 22, 2002 | 02:30 PM
Deus's Avatar
Those Blaus are 3" deep for the 12" which is the same as the Illusions. I'm planning a single 12" for my truck when it gets in although that may change to a single 15".
http://www.illusionaudio.com
Old Sep 22, 2002 | 03:57 PM
clonetek's Avatar
i've only got 140+ db so far.. but the system wasnt tuned & the subs were brand new.. its a little louder now..
makes your ears flap & nose itch too.. LOL
Old Sep 22, 2002 | 05:26 PM
clonetek, did you make that box or purchase it? thats a tight setup. thats the kind of thing im lookin for.Thankz for all the info guys.
Old Sep 22, 2002 | 09:23 PM
clonetek's Avatar
i had a guy make it.. it has .88 cubic feet per chamber.
Old Sep 22, 2002 | 10:15 PM
LLoverCrazyJay's Avatar
BUt those are Solo Baric L5's! Those would account to 3+ Normal 12"s like Kicker Comp VR 12"s EACH. Those subs rule, let me tell u! They are like 750 watts each, Dual voice coil.
Old Sep 22, 2002 | 10:21 PM
'00BlackLightning's Avatar
Here are my two Kicker 12" L7's
