E-fan help
Old Sep 21, 2002 | 08:33 AM
SLVRLTNG's Avatar
E-fan help
I got my e-fan yesterday and before I start shredding knuckles, my repair book says you need Ford tool "this "and Ford tool "that " which of course I don't have. I know you guys don't have them either, soooo what and how did you get your fan off???
ALL tips and tricks greatly appreciated, thanks...JR
Old Sep 21, 2002 | 08:46 AM
Chikenears's Avatar
JR,
Who made your fan?
Tim
S'CrewLoose's Avatar
Not sure what ford tools your thinking of, I know they suggest the tool for removing your OEM fan but mine came off real easy. I don't know if your 5.4 is the same as the SuperCrew 5.4 but if it is, the fan has regular right hand threads not left hand threads that are reported alot around this site. I used an 18" adjustable wrench to remove the fan and it came right off. Other than that I can't think of what other FORD tool you would need. Good Luck
Old Sep 21, 2002 | 08:50 AM
SLVRLTNG's Avatar
Originally posted by Chikenears
JR,
Who made your fan?
Tim
Tim,
it's the Flex-a-lite 270 dual electric fan. I bought it "almost new" you know how I seem to do that.... JR
Old Sep 21, 2002 | 08:53 AM
SLVRLTNG's Avatar
S'CrewLoose,
thanks... it says there is a special wrench to hold the fan clutch and another wrench to un-bolt the fan....
just more Ford "propaganda" I suppose......
Old Sep 21, 2002 | 08:54 AM
Chikenears's Avatar
JR,
Yep, you'll find a bargain, that's for sure!
Try going to JDM's site and look at their installation instructions for their fan. It shows the whole process which might differ from yours but the removal of the original fan will be the same. It worked for me, easy install. Time consuming but easy.
Tim
Old Sep 21, 2002 | 09:00 AM
SLVRLTNG's Avatar
Tim,
you da man!!!!
JR's recycled mods are alive and kickin' some serious a$$ around there parts!!!!
you know what they say about "one man's garbage", call me the "trash guy"...............
Old Sep 21, 2002 | 09:04 AM
Don's Bolt's Avatar
When I took my clutch fan off this is what I did.
I took a big vice grip and tightened it around the water pump shaft. Then I used a big adjustable wrench on the bolt on the fan to break it loose, just push the adjustable wrench towards the passenger side of the truck.
Here is a pic of the threads you can see what direction it goes on, or off
One more tip to remove the stock fan shroud, remove the top transmision line on the drivers side of the truck. This will allow you to get the shroud out a lot easier.
Old Sep 21, 2002 | 09:09 AM
Chikenears's Avatar
Lightbulb
You asked for it.
yUo iZ de TraSh gUy
Old Sep 21, 2002 | 09:25 AM
SLVRLTNG's Avatar
Thanks Don................
oh and I can't forget that damn rabbit.........
Old Sep 21, 2002 | 12:00 PM
Don's Bolt's Avatar
D
Hey no problem, let us know how you make out.
