Losing power on top end
Old Sep 19, 2002 | 12:16 AM
VINNIE's Avatar
I seem to notice at the track lately that from the 1/8 to the 1/4 my truck seems to fall flat on its a$$.I will be going along fine but it does not seem to pull hard.My MPHs have dropped and my times are also suffering.
Any suggestions-
These are a few of the things I will be looking at-
1.See if the plugs are fouled
2.Belt slippage.(although it does not feel it)
3.Everything is tight.nothing loose.
Any suggestions would be appreciatred
It pulls good off the line but just does not seem to pull hard through the whole 1/4.
VINNIE
Old Sep 19, 2002 | 12:18 AM
LightningTuner's Avatar
Vinnie, 9 times out of 10, that exact symptom is a burned plug. I suggest you pull all 8. If for nothing, at least you'll have the piece of mind.
Old Sep 19, 2002 | 12:30 AM
captainoblivious's Avatar
I say plugs to.
Vin - it's a shame I couldn't watch you run though to see if any thing looked odd or sounded off.
Old Sep 19, 2002 | 09:08 AM
VINNIE's Avatar
Thanks sal,
The plugs were captoblivious's idea.I guess I will be checking plugs.
VINNIE
Old Sep 19, 2002 | 09:09 AM
2Cool's Avatar
Wouldn't hurt to change the fuel filter as well, if its been a while.
Old Sep 19, 2002 | 09:15 AM
LIGHTNINROD's Avatar
Beat me to it! A clogged fuel filter will show up as a reduction in top end power as your eng. is trying(needs) to use every gram of fuel and the filter may be withholding some of the fuel and creating a pressure drop too.
Dan
Old Sep 19, 2002 | 09:18 AM
VINNIE's Avatar
It has been changed twice in 16,000 miles and has been O.K. each time.
Thanks for the suggestions.
VINNIE
Old Sep 19, 2002 | 02:40 PM
SVT_KY's Avatar
You're only running on 7 cylinders ??? <grin>
My MPH dropped back to about 101-102 when the
plug was bad ....
Old Sep 19, 2002 | 04:53 PM
Don's Bolt's Avatar
Yo Vinnie
I was talking to Jim today about something else, he asked me what was new on the boards so I told him about your post. He said to stop into the shop if you want and Richie will change you plugs for you.
Old Sep 19, 2002 | 05:46 PM
VINNIE's Avatar
Originally posted by Don's Bolt
Yo Vinnie
I was talking to Jim today about something else, he asked me what was new on the boards so I told him about your post. He said to stop into the shop if you want and Richie will change your plugs for you.
Thanks Don,
I will give them a call.
VINNIE
Old Sep 19, 2002 | 06:08 PM
wydopnthrtl's Avatar
Cool
If the easy stuff does'nt turn out to work. You might look for any plug-ups in the exhaust sys. If I'm not mistaken you can measure the backpressure upstream of the cats. Or at least I've heard of Ford dealerships doing this.
Just a long shot, but it's a possibility. WOT
Old Sep 21, 2002 | 12:06 PM
Don's Bolt's Avatar
Question
Vin did you find out anything yet??
