Rhino ramps
Old Sep 16, 2002 | 11:09 PM
Gyxer's Avatar
Angry Rhino ramps
Anybody else have problems with their rhino ramps sliding when tyring to drive up on them? Any suggestions on how to solve this problem without having to repave my garage?
Old Sep 16, 2002 | 11:12 PM
2020is's Avatar
Try putting a towel under them and make sure your garage floor is clean.
Old Sep 16, 2002 | 11:35 PM
mecca's Avatar
Ive found that if you hold your left foot on the brake and right foot on the gas just slighty, and you creep up slowely onto the ramps... they don't slide as easily. Also, like 2020is said, try a towel. Ive also used door mat's... (carpet on top, and rubber on bottom for traction)
-Mike
Old Sep 17, 2002 | 12:02 AM
JBLsilver01's Avatar
put a peice of duct tape on the back outer-bottom edge of it, and the floor, longways (if that makes sense )
Old Sep 17, 2002 | 03:50 AM
Ak.Silver2K's Avatar
Good question. I've had the same prob. Will try the door mat solution.
Mark
Old Sep 17, 2002 | 09:16 AM
RTKILLA's Avatar
No problem here and my floor is dusty as hell at work.
Old Sep 17, 2002 | 10:52 AM
Bluesky636's Avatar
I just bought a pair. Mine have thick rubber feet on them at the front and back of the ramp. Are you saying the rubber doesn't keep them from sliding? Thats what I was told it was for at Auto Zone.
Old Sep 17, 2002 | 02:58 PM
wolff's Avatar
Mine have the rubber feet too.
What about some 3m anti skid tape on the bottom?
Old Sep 17, 2002 | 05:56 PM
rickgig's Avatar
I went to Wal Mart and bought two rubber mats... the little rubber pads work on rough concret but not finished as in the garage...
Works great ever since.
Old Sep 18, 2002 | 12:09 AM
Gyxer's Avatar
My ramps only have the rubber pad on the front part of the ramp. I noticed that when I drive up on the ramps about six inches, the ramps bow and the rubber pad is not even touching the ground. At that point they start to slide. I'll try the rubber mat idea. Thanks for the suggestions.
Old Sep 18, 2002 | 12:54 AM
ChiDiver's Avatar
Thanx for asking about the ramps. I've had the same problem for a while and worked around it by using the ramps out on the driveway in moderate weather.
The ramps are sure quicker than a floor jack and stands for a lot of things.
I just wished they made them with 2 or 3 more inches of lift for us middle aged guys.:o
