Paul's Extrude Honed Upper Intake Manifold
Got it today! Promo says 10 HP and 20 torque. Anybody dyno one? Also appreciate any tips on installation (hose removals, gaskets, etc.)
FROM PAULS HIGH PERFORMANCE
SMOOTH AS A BABY'S BUTT!!
Mark
Mark
Originally posted by 02Thunder
Too much if it came from PHP!
You could have had yours Extrude Honed for $150.
joe
joe
My buddy is doing them for 100 bucks now. Any takers?
Originally posted by captainoblivious
Dremel, couple of flap wheels, sand paper, some water, and a couple hours.
May not look as perty, but just as smooth.
Just an FYI........it says on PHP's website that the intake is $500
That is friggin crazy.--Joe
Originally posted by TampaBlack99
I agree, a new Plenum from Fordpartsonline.com cost about $130, so there charging $370 for extruding and honing.
Sounds like a deal!
Sounds like a deal!
--Joe
It cost me $240 including shipping. Running out of things to change, next step is built up lower end. Silver Bolt said in his post that was the only thing he changed. Dont know if he already had a single bore TB or not.
Mark
Mark
That was the only part changed between dyno trips. I did already have a BABolt T/B. Do your self a faver and match port your T/B to the new intake. Then make sure the T/B is aligned and tightened before you install the upper. If you put the upper on first it is very hard to properly align the T/B. If you have a single blade T/B and you hear that little whistle at part throttle, you are not aligned.
