quick Question
Old Sep 9, 2002 | 09:07 PM
SLVRLTNG's Avatar
quick Question
I am getting ready to install my factory tech valve body.. I got Mercon III fluid, is this right? It says use Mercon not Mercon V but is III the same as regular mercon??
thanks, I am Waiting ti drain my tranny...JY\R
Old Sep 9, 2002 | 09:13 PM
red00Lightning's Avatar
I think III or IV will be ok. I think I used III as well.
--wes
Old Sep 9, 2002 | 09:19 PM
SLVRLTNG's Avatar
thanks wes, I'm ready to drain now...JR
Old Sep 9, 2002 | 11:32 PM
superfords's Avatar
use only mercon III
NOT mercon V
check your owners manual.
the two are not compatible.
I think that you can probably use one or the other if you do a complete drain/refill including the converter, but you really should not mix the two.
