Amount of boost w/6# lower pulley??
Old Sep 9, 2002 | 12:36 AM
Ylw 98~~SNAKE~~'s Avatar
Question Amount of boost w/6# lower pulley??
Just wondering how much boost you guys are getting w/ a 6#lower pulley. When first installed my stock gauge would just barely go past 10#. Well I just installed an Autometer boost gauge and it read just a little over 10#s. I'm mean I was getting 9#s with stock pulley. There are no leaks anywhere and yes I put thread sealant on the gauge. What gives. Here's a list of mods:
JL6# lower
JDM Flip Chip
Boost Bypass
Spintech Catback
Offroad Pipe
Old Sep 9, 2002 | 01:15 AM
air1kdf's Avatar
Simple,
Your leaking somewhere!
Now the question is where. It may be internal. That's a lot of boost to be loosing, and I would be a little concerned about it. There must be a way to test the system.
Old Sep 9, 2002 | 01:31 AM
detail's Avatar
you should make sure you really have a 6lbs pulley......sometimes they can grab the wrong one and you'll be running a 2 lbs and scratching your head
Old Sep 9, 2002 | 12:02 PM
SVTMoonshine's Avatar
Ok how big is a 6#'er? I assume we should be able to get a rough feeling by using a tape to measure it.
As far as just getting over 10 w/ a 6lber... that's about what I get (11lb). I believe this is because of my altitude.
I know that my brother went down to california in a turbo powerstroke and got 2lbs better when he got down there. Figure that's something I'll have to give up by living up here.
But I can run a 100 octain program up here on pump gas w/ no problem.
Old Sep 9, 2002 | 12:37 PM
LIGHTNINROD's Avatar
Maybe your OEM air box is choking off your air intake??? We need more info: Any other symptoms, hesitation, misfiring, miles, year, etc.???
Dan
