coil spring r&r question
Old Sep 3, 2002 | 05:55 PM
droptail's Avatar
Does the lower control arm ball joint need to be separated for front spring removal?
Old Sep 3, 2002 | 05:59 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Nope
using a floor jack with the spring slightly compressed and the shock removed, remove the bolts on the upper A arm.
SLOWLY lower the floor jack. spring will fall out.
best to use a safety chain in between the coils and the frame also.
Bob
Old Sep 3, 2002 | 06:17 PM
TampaSVT's Avatar
Posting Rights Suspended
From: I drive way too fast to worry about cholesterol.
Thumbs up
Correct, as usual...
Old Sep 3, 2002 | 06:52 PM
Fast Gator's Avatar
Sir Speedin is correct, especially about the safety chain. Its smart to use one if you have never done this before
Old Sep 3, 2002 | 07:29 PM
Silver-Bolt's Avatar
Or you can do the ball joint. Better to do the upper bolts because you need to replace them with cam bolts anyway.
Old Sep 4, 2002 | 12:17 AM
droptail's Avatar
Yes, I'm doing the cam bolts thanks to you guys. What a wealth of knowledge, you guys are great, thanks.
Old Sep 4, 2002 | 12:39 AM
speeder's Avatar
Question cam boltd
Does anyone have a picture showing how the cam bolts are installed?, I just ordered a 3/4 drop kit from the online store and will be getting the cam bolts from in the next week or so, I just don`t know how to install them.
Larry.
Old Sep 4, 2002 | 06:31 AM
SLVRLTNG's Avatar
Here's some install pics from an old thread:
https://www.f150online.com/forums/sh...threadid=62144
Old Sep 4, 2002 | 10:18 AM
speeder's Avatar
Question cam bolts
I read all of those old threads before but none of them show were the cam bolts go. does anyone have a picture or anything that shows how they are installed?.
Larry.
Old Sep 4, 2002 | 11:42 PM
speeder's Avatar
Question cam bolts
Does anyone have a picture showing how the cam bolts are installed? come on guys, help me out here.
Larry.
