Hey Don
Hey Don
I just read this thread:
https://www.f150online.com/forums/sh...ING+COMPRESSOR
and was wondering if you have any pics of what your talking about. I dont know much about suspension but am goin to attempt to install the FRPP kit I ordered my self. any pics or more detail would be appreciated.
thanks
thanks
Throw away the instructions!!!
The instructions basically tell you to disassemble the entire front end.
I am about to install mine, and I think I will follow Don's advice. I'll take some pics along the way and post them (if it goes alright)
Well, I did it like Don described and it was no problem.
Here are a few pics. some of them are not great. I'm still learning how to use this new digital cam.
Anyway hope it helps.
Don,
Thanks for the advice. I think it may have saved a lot of people, including me, some fustration.
I just finished putting everything together and it's dark now so I guess I won't be able to get a good look at it until tomorrow.
Here are a few pics. some of them are not great. I'm still learnig how to use this new digital cam.
thanks
Remove all the nuts with a jack under the lower control arm for support. When all the nuts are removed, lower the jack until the suspension bottoms out and hammer where shown to knock the ball joint loose. Continue to let the jack down until the spring comes out easily.
A few notes:
Undo the ABS sensor wire from the control arm (shown) to give it some slack and do the same with the brake hose.
Jack the truck up as high as possible before putting it on jack stands or you won't be able to lower the suspension enough to get the spring out.
For any questions my e-mail is: SVTBlackLight01@aol.com
A few notes:
