Help!!!
Old Sep 3, 2002 | 03:28 PM
PFA's Avatar
PFA
Help!!!
I need some input PLEASE!
I am having a problem accelerating. At idle and light gas, the L runs fine. When I get into the boost, it feels like it is dropping off, badly! My gauge shows full boost. It just started doing it this afternoon. This morning when I parked it, it was fine. If I gas it in park, it does the same thing around ....say 3000 rpms.
Any suggestions on what it is? I was thinking the fuel filter, but not sure what it does when that is bad.
HELP!!
Old Sep 3, 2002 | 03:44 PM
Silver-Bolt's Avatar
Start with the fuel filter then check the plugs. Chip??
Old Sep 3, 2002 | 03:52 PM
BadDog's Avatar
Wayne,
I just had the exact same problem last week. It was the fuel-pump hose/clamp coming off. I could nurse it along and it ran (sort of), but as soon as I got into it, it just lost power.
Gordon
Old Sep 3, 2002 | 04:05 PM
PFA's Avatar
PFA
Originally posted by BadDog
Wayne,
Gordon
Is this the OLD problem that alot of people were having in the tank? (long ago)
Old Sep 3, 2002 | 04:19 PM
BadDog's Avatar
Yup.
And to my great displeasure, it happened to me just 3 weeks out of warranty. I filed a claim w/Ford. Hopefully I'll get a couple $$ back.
Old Sep 3, 2002 | 04:36 PM
wydopnthrtl's Avatar
I don't know.
However if it's dieing under load it sure sounds like fuel starvation to me.
Old Sep 3, 2002 | 05:12 PM
PFA's Avatar
PFA
I'm going to try the filter first. I hope it's it.
Hi Gordon. Good to hear from ya!!
Old Sep 3, 2002 | 07:59 PM
SVT_KY's Avatar
2001 ? Friend of mine just dropped the hose
in the tank on his 2000 ... Ran like SHEAT ...
couldn't even back it up the driveway ...
Old Sep 3, 2002 | 10:35 PM
PFA's Avatar
PFA
It's a 2001
chip
cone filter
4Lb'r
Oval TB
Changed filter and reset computer and new gas as low level came on. No change. Any more suggestions?
Is it hard to get to the fuel pumps? Anyone have a how-to on it?
Old Sep 4, 2002 | 06:00 AM
loosebolt's Avatar
How To
Wayne,
I have a how-to, but it's on old fashioned paper. I can fax it or you can pick it up.
Old Sep 4, 2002 | 03:55 PM
PFA's Avatar
PFA
I may need to get those directions from you. I got the codes checked. Lean banks, 1 and 2. Need to get a gauge to check the fuel pressure now. Most likely the pumps or T.
Old Sep 4, 2002 | 10:08 PM
PFA's Avatar
PFA
Thanks everybody for the replies. It appears to be in the fuel pump area. Pressure gauge showed that to be evident.
Thanks again. Time to go to work.
Old Sep 8, 2002 | 03:51 PM
PFA's Avatar
PFA
Post
Found the problem. From what I've read, I'm suprised it still ran.
Old Sep 10, 2002 | 02:55 PM
cobra97snake's Avatar
hey pfa i've seen you around belleville before, i've got a silver L, you got the thumper on the side of yours, i've seen you on main st.
