Line-lock help?
Line-lock help?
Getting ready to install a line-lock. I am going with the single solenoid Hurst unit mounted before the ABS. I know to use the front port of the master cylinder. My question is the Hurst unit has 1 in port and 2 out ports. I run one line from the master cylinder to the Hurst in port. Where do the out ports connect? Do I plug 1 and plumb the other one into the ABS modual? Which port gets plugged? Or do I run both out ports into a "T" fitting then back to the ABS mod? The install instructions does not cover ABS installs.
Bill, the ABS doesn't matter on your installation. The line lock solenoid simply goes in line with the line from the master to the ABS module. Check the Hurst directions, and plug off the unused port so that it's a single line in and single line out setup.
HI!... I've had a brand new HURST line-lok in my garage now for 4 years. I am also wanting to install it on my truck. Does anyone have "IN DETAIL" pics of how they did their's??????? Any speical fittings needed????? Thanks in advance.
When I actually install it I will post some pics. Just getting everything lined out and making a custom bracket for it. As soon as the rest of my brake parts come in I will do the install. Only want to bleed them once.
