TR6's - How tight?
Old Aug 29, 2002 | 08:59 PM
JBLsilver01's Avatar
TR6's - How tight?
I've hear to use anti-seize. Is this a good idea?
And I've also heard "finger tight, then 1/16 turn" but that just doesn't seem to be tight enough.?
Any help would be great
Old Aug 29, 2002 | 09:20 PM
ally69's Avatar
You will be luck to get a 16th of a turn when I did mine I ran them down until they were good and snug but not forceing them tight.
Old Aug 30, 2002 | 12:11 AM
captainoblivious's Avatar
Re: TR6's - How tight?
That is a great method for tightening them.
As for anti sieze. I used it the first time I changed the plugs. But going forward I'm not going to bother at all. I plan an changing the plugs every 10k miles. Also I will pull any plug and check it at any given time to make sure the engine is running good.
So if I suggest that if you are a person to put the plugs in a forget about them for a lot of miles, then use anti-sieze. Anything else don't bother.
Old Aug 30, 2002 | 09:43 AM
LIGHTNINROD's Avatar
Smile
Sal recommended the "snug plus 1/16th of a turn more" and my NGKs have been in 14,000 miles with several WOT passes made too. I used a copper-based anti-sieze.
Of course, he also said "he doesn't use anti-sieze" but I did. What the heck does he know?
Snug/finger-tight plus 1/16th of a turn more and you'll be OK.
Dan
Old Aug 30, 2002 | 10:39 AM
HIHOAG's Avatar
Maybe I am way too **** but I used a torque wrench.
160 in-lbs.
Old Aug 30, 2002 | 11:07 AM
svt360's Avatar
Finger tight is how they come from the factory!!!!what are you gapping them at???i have some on order to go with my 4# pulley,ive heard .042
Old Aug 30, 2002 | 11:17 AM
Mark John's Avatar
Thumbs up torque em
If you go to www.NGK.com it has a section under "tech tips" that tells you how tight you should go and other suggestions. I got to hand it to you guys that even try to change these plugs. Sorry....www.ngksparkplugs.com and then tech info
Old Aug 30, 2002 | 12:57 PM
Don's Bolt's Avatar
I go good and tight then I tighten them up a little more.
Old Aug 30, 2002 | 01:49 PM
svt360: I gapped mine at .40 - seemed to be the average of all the recommendations I got. Some told me .38, some .42 - Just went with .40
