Disabling the ABS
Old Aug 28, 2002 | 12:50 PM
Silver-Bolt's Avatar
Disabling the ABS
How can I safely disable the ABS? Can it be done without the dash light coming on? Can it be done through the chip? Hoping for an easy way to disable it for the track and reactivate it for the street.
Old Aug 28, 2002 | 12:57 PM
SVT_KY's Avatar
As I "stutter" braked around a corner last week, I
was very much wishing for a solution also, and
will be waiting with bated breath for the answer!!
Old Aug 28, 2002 | 01:10 PM
easterisland's Avatar
I remove the fuse closest to the engine and towards the cab. The fuses which are in the engine compartment. I hope that is the ABS fuse...
Old Aug 28, 2002 | 01:16 PM
MRBBQMAN's Avatar
Wink
you're going to get a code+light!
Old Aug 28, 2002 | 02:37 PM
Would a basic code scanner be able to clear the code and reset the light once the ABS is reactivated? I wish they would go back to making ABS an option. I could do without it.
Old Aug 29, 2002 | 03:17 PM
Robert B. Chuhran's Avatar
Talking Disabling the ABS
Silver-Bolt,
I always pull the abs fuse at the strip and have never gotten
a lite or code on my "99" Lightning. If you do just have Auto Zone reset it for you.
Old Aug 29, 2002 | 06:36 PM
Thanks guys. Sounds like the fuse is quick and easy.
Old Aug 29, 2002 | 08:37 PM
RTKILLA's Avatar
an autotap can clear the codes also.
