Order for Top 10 Modifications for '02
Old Aug 25, 2002 | 09:02 PM
Cobra Marty's Avatar
What order of mods would you do first? Number 1-10. And whose product?
Air box, throttle body, extrude upper, upper pully, lower pully, breather, trans, shackles, cat back exhaust, headers-long of short tube, high flow cats, chip, etc.
Thenks.
Old Aug 25, 2002 | 09:11 PM
Probleminfected's Avatar
1. drop shackles (any)
2. chip (psp)
3. filter (any)
4. pulley (JDM)
5. beather (any)
6. valve body (factory_tech, psp)
7. t/b (any single blade)
8. back cat (mac or jdm)
9. headers w/cats (jdm or psp)
10. extrude/polish horn (any one that will do it)
upper pulley isn't needed, just put a larger lower on
Old Aug 25, 2002 | 09:22 PM
JBLsilver01's Avatar
1 chip
2 filter
3 pulley
4 traction bars
5 ET Streets / Hoosiers
6 t/b
7 breather
8 valve body
9 cat back
10 headers
Any tuner is good out of the big 3
cost effective = JLP > PSP > JDM
All have good quality parts
Plan mods (if possible) so you can program chip accordingly
Old Aug 25, 2002 | 09:24 PM
Lightning Boy's Avatar
Originally posted by JBLsilver01
1 chip
2 filter
3 pulley
4 traction bars
6 t/b
7 breather
8 valve body
9 cat back
10 headers
Couldn't have picked a better order....
Old Aug 25, 2002 | 09:28 PM
soap's Avatar
I concur w/ L Boy.
--Joe
Old Aug 25, 2002 | 09:29 PM
RTKILLA's Avatar
Performance Mods
1,2,3: chip, filter, pulley
4, factory tech valve body with 4x4 tranny pan
5, electric fan
6, Cobra R water pump
7, throttle body
8, Slicks
9, traction bars
10, cat back
Cosmetic mods:
1, drop kit
2, 20 inch chrome wheels
3, grilles
4, bedrug
5, ram air hood or cowl hood
Old Aug 25, 2002 | 09:36 PM
Rob_02Lightning's Avatar
Cobra Marty,
If your going to put those ten mod's on then Probleminfected has the right order for Him and most of us. I haven't done 6-10 myself yet and truly believe they get less and less rewarding in the improvement department as you get down the list. For me performance was first, so I went
1. Diablo Chip (Custom Program) Pick a Tuner you trust.
2. Filter (12" Hi Flow w/secondary air input) I used JDM's most are simular.
2-a. Boost By-Pass (A MUST, "YOU NEED THIS") Mine is JDM
3. Pulley (I have 2 Upper + 4 Lower) I like non cage Lower and Dial-Ur-Boost Upper to give me 5 minute tune-ability. (they're all good)
4. Beather (I have JDM)
5. Drop shackles (any) "THIS IS MY NEXT MOD"
6. t/b (any single blade) "THIS WILL BE MY 2nd UPCOMING MOD"
7. valve body (factory_tech, psp) "Sounds good to me"
8. back cat (mac or jdm) "Sounds good to me"
9. headers w/cats (jdm or psp) "Sounds good to me"
10. extrude/polish horn (any one) "Sounds good to me"
Old Aug 25, 2002 | 09:44 PM
EXCITED's Avatar
breather?
why do the oil breather ?not a really good mod.
1. it dont work
2. doing the pvc valve filter is better = really gets the oil =oil seperator/not breather but what do i know,i did the oil seperator and it [works]
Old Aug 25, 2002 | 10:07 PM
HIGH ROLLER's Avatar
This is my order:
1. Chip
2. Filter
3. Pulley
4. Valve Body
5. 160 Thermostat
6. Traction Bars
7. Slicks
8. Throttle Body
9. Electric Fan&Waterpump
10. Longtubes&Catback
Old Aug 25, 2002 | 10:10 PM
soap's Avatar
Originally posted by HIGH ROLLER
This is my order:
1. Chip
2. Filter
3. Pulley
4. Valve Body
5. 160 Thermostat
6. Traction Bars
7. Slicks
8. Throttle Body
Hey that's 12
Nice sig Matt.........see ya Friday, your going down
--Joe
Old Aug 25, 2002 | 10:26 PM
FalconGTHO's Avatar
Fipk or Air Raid (Does K&N even MAKE an FIPK for Ls)
X pipe, Ultra or Magna Flows
Long tubes
Pulley to 10 psi
Chip to match
Spark amplifier
Lower one, two gearset for trans (Does anyone make this?)
Electric fan
Torque converter (but Im NOT a big fan, regardless of the improvement)
Not sure what else thats simple.
Old Aug 25, 2002 | 10:36 PM
soap's Avatar
Long tubes
Sorry man but your top 3 are BAD!!!!! Why spend $1900 ($1300 long tubes, $400+ catback, $200 filter kit) for like .3 reducion (at most) in ET, when you can get a chip, pulley for $600 max and knock 1 second or more off your ET
--Joe
Old Aug 26, 2002 | 02:35 AM
This is great, just what I wanted to see. Thanks.
Old Aug 26, 2002 | 08:39 AM
Tim Skelton's Avatar
Here's my plan (street + road race):
Done:
1. Factory Tech valve body, B&M tranny pan
2. Hotchkis springs (+cam bolts, Herb's washers)
3. Hotchkis anti-sway bars
4. QA1 shocks
4.5 Remove spare, class II hitch
Next:
5. LFP/Metco upper link traction bars
6. Brembo brakes
7. Tranny/oil/diff temp gauges
8. Transmission cooler
9. Diff cooler
10. Engine oil cooler
11. 6-point harnesses
12. Cold air tube to stock airbox
13. 4 lb pulley, chip with lowered redline
14. Boost gauge
Mine looks substantially different from the others, but attacks the weakest points first.
TLS
Old Aug 26, 2002 | 09:00 AM
01Lightning's Avatar
Hey Tim, how much of an improvement did you get after installing the FT Valve Body with the torque reduction still active? I am thinking of doing that before I get a chip also. I do plan on chipping mine shortly thereafter, but I am just thinking ahead. My plan is to get the valve body and then having the chip programmed without torque reduction or line pressure increase.
